![]() Join Date: Sep 2004
there are two different types of 02 senors, a skinny 02 sensor and a fat 02 sensor. The FAT 02 sensor's on your ka24de will not fit in that elbow you will need the skinny 02 sensor.
the skinny O2 bung can also be removed i believe its an 1" wrench or something like that and the remaining hole is i believe the proper size for the big O2. or dont run any o2 sensor b/c its not gonna compensate on the ka ecu for any of that jazz.. you should be running an afc / wideband at the very least. if you remove the o2 you have less of a chance of the ecu pulling/adding fuel and you control everyhting.
#7 | |
![]() Join Date: Dec 2002
To the OP - you use the sensor that came on your car. Not that hard to figure out.
#8 |
the sensor that is for my car dosent fit the holes, either a bit too big and then the reducer for the skinny is well wayy too skinny for the stock o2 sensor.. and i have a tuned ecu so i kinda need the o2 sensor
#10 |
![]() Join Date: Jul 2003
The auto-parts stores and exhaust shops have o2 bungs. Go find one then remove the one in the pipe and replace with new one or just take the pipe to an exhaust shop with your O2 sensor and say "here ya go"
#12 |
There are 2 types of o2 sensor the 3 wire ( Skinny Type ) on the earlier SR and the 1 wire ( Bigger o2 sensor ) on KA and some SRs. You would obviously need the 1 wire so either get a torch or soak it on WD40 maybe liquid wrench also to remove the skinny bung on the SR elbow and do the same on your stock exhaust manifold and then re use the bung from your stock EX manifold on the SR Elbow. GL!!
