Old 06-17-2009, 02:40 AM   #1
Renelovesnike
Renelovesnike's Avatar
Trader Rating: (30)
Renelovesnike is an unknown quantity at this point
Feedback Score: 30 reviews
s14 hi im new
hello my name is Rene (male) live in (562) CA and just bought my fist car (95 s14) and was wondering if any parts from an s13 are interchangeable like the clutch pedals or clutch maser cylinder? due to my car is auto(changing to stick) and my friend has an extra 1990 240sx shell that he said i could take what i need!
thanks fo all the help beforehand!
Renelovesnike is offline   Reply With Quote
Old 06-17-2009, 02:45 AM   #2
Zenki_Kouki.5
Zenki_Kouki.5 is an unknown quantity at this point
You can use it but i heard you have to get an s14 std driveshaft
Zenki_Kouki.5 is offline   Reply With Quote
Old 06-17-2009, 03:07 AM   #3
GSXRJJordan
GSXRJJordan's Avatar
Clutch, clutch master, clutch hardline (with a little bending - connect it directly to the slave cylinder's rubber line, don't swap over the clutch damper box), slave, trans - basically everything except the driveshaft.
Old 06-17-2009, 03:25 AM   #4
Renelovesnike
Trader Rating: (30)
thanks and whats the slave damper box?? could i use the auto driveshaft i already have on my car with a manual tranny or i need a manual driveshaft too??
do clutch and break peddles bolt right up and work normally or do i need to find s14 ones??
Old 06-17-2009, 03:34 AM   #5
GSXRJJordan
The clutch damper box is a stupid 4-way splitter with a loop-back that's supposed to 'dampen' the clutch pedal movement - it's lame. You'll see it connected between the clutch hardline (from the m/c) and the slave line once you get under your buddies donor car.
You will need a M/T driveshaft. They're all different sizes. Going price for a S14 M/T driveshaft is ~$150, but you can get 1pc steel ones (that weigh like half of what the OEM weighs) for $200... that's what I'd recommend.
Pedals might bolt up, I don't know. Might as well try
Old 06-17-2009, 03:39 AM   #6
Renelovesnike
Trader Rating: (30)
thanks ALOT for the info if i need any more help i know who to hit up!!!
that is if its cool with you gsxrjoran??
