![]() Whats up guys, just need some clarification whether or not this ECU is compatible with my s14 Zenki SR.
Picked up this ECU off a forum member here and he told me it came off his Zenki SR. He had never run it after getting it back from having the daughter board soldered in (Nistune). I hooked it up in my car and my car ran with the ECU in but it was having some idle issue. Whenever i would come to a stop the car would drop RPM's to about 200-500RPM. I'm thinking it's because i need to have the ECU fine tuned since it only has a base map of the list i gave him that was on my car.... Well enough of that. Here are the ECU's. The red one is the one i got when i purchased my front clip, and the black one is the one i purchased a couple days ago. Thanks guys! ![]() ![]() |
#5 |
Believe i found my answer! Was looking at zilvia posts and it seems Norm had the answer on a diff post.
Forgot where I got this from but I believe it's correct: ECU Codes RED WC is from a 95-96 S14 Silvia Zenki BLACK WC is from a 96-97 S14 Silvia Chuki (transition, different MAF plug) NA is from a 97-98 s14 Silvia Kouki 5 speed 62 is from a 91-93 180sx or S13 Silvia 5 speed 63 is from a 91-93 180sx or S13 Silvia automatic E5 is from a 94-96 180sx black top 5 speed E6 is from a 94-96 180sx blacktop automatic J4 is from a 97-98 180sx Kouki 5 speed J5 is from a 97-98 180sx Kouki Automatic Also: S14 Zenki SR20 with Red WC ECU has a rectangle MAF plug S14 Chuki SR20 with Black WC ECU has an oval MAF plug, S14 Kouki SR20 with Black NA ECU has an oval MAF plug |
