Old 06-20-2009, 09:40 AM   #1
mattro
mattro's Avatar
mattro is an unknown quantity at this point
SR uh oh timing chain q
so i get done swapping in my new 1.01 head gasket, put the timing chain back on the cams put the vc back on and give the engine a "spin" with my hands to make sure everything is good. the problem is that when i did this the chain "skipped" some teeth on the gear. i know this for a fact. i have to go back in and put the chain back onto the correct spot on the teeth right?
sr20 engine
amd the engine still spins by hand freely, (by hand) the pistons dont touch the valves.
mattro is offline   Reply With Quote
Old 06-20-2009, 09:43 AM   #2
Banegraphix
Banegraphix's Avatar
Banegraphix is an unknown quantity at this point
You are correct I have had this happen before when i changed my chain tensioner. The only sure fire way to get it all back to where it needs to be is to just reinstall the timing chain.
Banegraphix is offline   Reply With Quote
Old 06-20-2009, 06:11 PM   #3
Ceepo
Ceepo's Avatar
Ceepo will become famous soon enoughCeepo will become famous soon enoughCeepo will become famous soon enoughCeepo will become famous soon enough
Better safe then sorry double, triple, quadruple check it lol...
Ceepo is offline   Reply With Quote
Old 06-26-2009, 03:45 PM   #4
mattro
mattro's Avatar
that would be awesome but i dont have a pulley puller and cant get the pulley off to pull the cover. plus i REALLY dont want to take my head BACK off. any other ideas?
Old 07-01-2009, 02:15 AM   #5
Tantwoforty
Tantwoforty's Avatar
Tantwoforty is an unknown quantity at this point
just retime the whole thing if your not sure, dont wanna smash into a valve, its not that hard really, tdc, set the cams, install the chain time thedizzz, i just did it to mine while i did my head gasket
Tantwoforty is offline   Reply With Quote
Old 07-16-2009, 02:40 PM   #6
mattro
mattro's Avatar
yep did it, got some new arp's in there to.
Old 07-16-2009, 10:31 PM   #7
aNskY
aNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfection
Send a message via AIM to aNskY
you dont have to do that, just put it on tdc and use the link counting method. http://www.rs-enthalpy.com/tuning/sr-cam-alignment.doc
aNskY is offline   Reply With Quote
