Old 07-08-2009, 05:23 PM   #1
ichibans13.5
ichibans13.5's Avatar
ichibans13.5 has made poor choicesichibans13.5 has made poor choicesichibans13.5 has made poor choicesichibans13.5 has made poor choicesichibans13.5 has made poor choicesichibans13.5 has made poor choices
s13 Full s13 Rear Subframe-Helical-Nismo-Por 15-MR
I have up for sale a s13 rear subframe that was stripped down by sand blasting- then coated in POR 15 -a bad ass rust resistant coating (look it up). These components were never driven on just installed and aligned by eyeball but car was never finished- some of the blue paint lost some of its shine or chipped a little from adjustment and then taped up to protect
$1000 Firm Picked Up Right Outside Worcester MA
Nismo Subframe bushings pressed in
Full adjustable suspension components with megan racing adjustables
Megan racing rear adjustable traction rod-
Megan racing rear adjustable lower toe arm-
Megan racing rear upper camber arm
New OEM camber bolts
Energy Suspension Red Poly bushings installed
S15 Helical Rear Diff with brand new Output shafts installed and Shimmed by DSG (dent sport garage) then the rear cover was polished, a new oem rear diff gasket was intalled and filled with motul fluid
ichibans13.5 is offline   Reply With Quote
Old 07-10-2009, 09:37 PM   #2
ichibans13.5
would do the subframe and adjustable arms with nismo subframe bushings for $400 without the diff/axles
Old 07-14-2009, 07:47 AM   #3
ichibans13.5
i have a 5 speed non abs driveshaft also for a lil extra $, if anyone is looking to use this kit to eliminate HICAS and abs
Old 07-17-2009, 11:04 AM   #4
ichibans13.5
bump for someone to buy this!
Old 07-21-2009, 12:06 AM   #5
jspeedm
jspeedm's Avatar
Trader Rating: (26)
jspeedm is on the path to ruinjspeedm is on the path to ruin
Feedback Score: 26 reviews
will you sell just the diff?(not pumkin, just diff) if so, how much shipped to 90706?
http://i404.photobucket.com/albums/pp128/jspeedm/Picture097.jpg
jspeedm is offline   Reply With Quote
Old 07-21-2009, 08:28 PM   #6
ichibans13.5
dont want to pull the diff from the pumpkin cause then its a waste of a new gasket- motul fluid- and the price i paid DSG to shim it
helical, megan racing, nismo, s13, subframe
