Old 04-17-2003, 12:30 AM   #1
jamik_69
jamik_69 is an unknown quantity at this point
Send a message via ICQ to jamik_69 Send a message via AIM to jamik_69
replacement sr20det parts
hi i was wondering what parts should be replaced when i get my sr20 and what should i replace them with (ie) waterpump, sparkplugs, oil filter, belts, timing chain, fuel filter, sensors
i think the anwsers should be poasted in the faq
thank you
jamik_69 is offline   Reply With Quote
Old 04-17-2003, 03:31 PM   #2
speeddreamz
speeddreamz's Avatar
speeddreamz is just really nicespeeddreamz is just really nicespeeddreamz is just really nicespeeddreamz is just really nicespeeddreamz is just really nicespeeddreamz is just really nicespeeddreamz is just really nicespeeddreamz is just really nicespeeddreamz is just really nice
Send a message via AIM to speeddreamz
waterpump - If im not mistake, a sr20de waterpump will work from a sentra
sparkplugs, - sentra again, the b12 version, or even a 300zx twin turbo plug will work, I bought some nippon denso irridiums...great!
oil filter, - you can use again, the sentra sr20de from a b12 thats like the 93ish version, or even a ka24de if you dont like the small ass oil filter. I've used a ka24de one and it works fine and a sentra one, it works fine. I'd advise if you get a sentra, you get the k&n oil filter, its got a 1 inch screw on the top u can use to install/remove the filter
belts, - Not sure on this one try heavythrottle.com or jspec.com
timing chain, - again same as belts
fuel filter, - u can use a 300zx twin turbo one if u want or a nismo one
sensors - MAF off a 300zx 90+ and a o2 sensor from a z31, the older 300zx's
hope this helps
speeddreamz is offline   Reply With Quote
