Group Buys Dedicated Forum for Group Buys. |
![]() Join Date: Jul 2009
![]() Feedback Score: 27 reviews
![]() Godspeed Power Parts Group Buy!
Everything in stock and READY to SHIP AND PICK UP!!! Turbo is the BEST!! Nissan 240SX 89-90 KA24 (S13) Single Cam (KA24E) T3T4 Complete Turbo Kit ![]() -T3T4 Turbo Charger .63ar -KA24E Stainless Top Mount Manifold -Aluminum Pre-Bent intercooler Pipe, With Clampes & Silicone -3" Staninless Turbo Uppipe -3"Stainles Turbo Downpipe -Godspeed 38 Wastegate (7PSI) -Oil Feel Line, Oil Return Line With All Fittings -Type RS Blow Off Valve NISSAN 240SX 91-94 KA24 (KA24DE) DUAL CAM MOTOR T3T4 COMPLETE TURBO CHARGER KIT ![]() -T3T4 Turbo Charger .63ar -KA24DE Stainless Top Mount Manifold -Aluminum Pre-Bent intercooler Pipe, With Clampes & Silicone -3" Staninless Turbo Uppipe -3"Stainles Turbo Downpipe -Godspeed 38 Wastegate (7PSI) -Oil Feel Line, Oil Return Line With All Fittings -Type RS Blow Off Valve TD04-H T25 TURBO CHARGER Turbo spec. Intake in: 37.8 ex: 59.7 Exhaust in: 45.47 ex: 52.9 Internal Wastegate Set at 8PSI Start Spooling At 2500RPM ![]() GODSPEED 38MM GT-SERIES 38MM WASTEGATE (universal) ![]() - comes with 7psi waste gate spring ( fully adjustable ) - dual port. accurate boost - ultra durable diagram (diaphram) - comes with all the hardware (bolts, gasket etc) - accurate boost pressure - high quality appearance - 1 year warranty ( if installed by professional) - comes with additional 11 psi, 15 psi springs this wastegate is only 4.35" tall. very compact especially good for customer working with small / tight engine compartment. GODSPEED GT-SERIES 44 MM V BAND DUAL SPRING WASTEGATE (universal) ![]() -comes with 15psi waste gate spring ( fully adjustable from 10- 15 psi ) and extra 14psi spring ( if you add both spring that makes it 29 psi total ) -accurate boost pressure , prevent over boosting. -high quality aluminum die-cast body -ultra durable high temperature diaphragm -comes with all the hardware ( v band, clamps and etc) -stainless steel valve -high quality appearance. -1 year warranty ( if installed by professional) GODSPEED GT-SERIES 50 MM V BAND DUAL SPRING WASTEGATE (universal) ![]() -comes with 20psi waste gate spring ( fully adjustable from 15-20 psi ) and extra 7.5 psi spring ( if you add both spring that makes it around 27 psi total ) -accurate boost pressure -ultra durable diagram (diaphram) -comes with all the hardware ( v band, clamps and etc) -high quality appearance. -1 year warranty ( if installed by professional) GODSPEED GT-SERIES 60 MM V BAND DUAL SPRING WASTEGATE (universal) ![]() -comes with 24psi waste gate spring ( fully adjustable from 15-24 psi ) and extra 7.5 psi spring ( if you add both spring that makes it around 30 psi total ) -accurate boost pressure , prevent over boosting. -high quality aluminum die-cast body -ultra durable high temperature diaphragm -comes with all the hardware ( v band, clamps and etc) -stainless steel valve -high quality appearance. -1 year warranty ( if installed by professional) Nissan S13 SR20DET Intake Manifold Three Style available Cast, Polished, Chromed Cast ![]() Polished ![]() Chromed ![]() S13 S14 240SX Top Mount T3 Turbo Manifold ( sr20det motor ) ![]() - T3 Turbo Flange. FIT T3 AND T3T4 HYBRID TURBO - 35MM or 38MM external wastegate flange - SUS321 stainless steel S13 S14 240SX SR20DET T3 Top Mount Cast Turbo Manifold ![]() - extremely strong casting - fits sr20det motor (s13, s14 ,s15) - 38mm wastegate flange ( will fit 35mm or 38mm wastegate) - t3 flange. fit all t3 or t3t4 hybrid turbo - life time warranty SR20 TOP MOUNT MANIFOLD + 3" STAINLESS DOWNPIPE + WASTEGATE DUMP TUBE ![]() -FITS : TOP MOUNT T3 OR T3T4 TURBO CHARGER -extremely strong stainless steel -equal length for quick throttle response -3" 5 bolt standard flange turbo downpipe -T3 turbo flange -38mm wastegate flange -able to retain A/C power steering -fully TIG welded -Fully ported and polished -includes all gaskets -1 year warranty S13 S14 240SX top mount t3 turbo manifold ( KA24DE motor ) ![]() - T3 Turbo Flange - 35MM or 38MM external wastegate flange - SUS321 stainless steel - Fully TIG welded - Fully Ported and Polished - Includes bolts and gaskets KA24DE(dual cam) T3 or T3T4 or T4 Top or Bottom Mount Cast Turbo Manifold ![]() - 91-94, 95-98 Nissan 240sx KA24DE (Dual Cam) - 93-01 Nissan Altima - Extremely Strong Casting - 35MM or 38MM External Wastegate Flange - T3 or T4 Flange - life time warranty Nissan 180SX (CA18DET Only) T25 Bottom Mount Turbo Manifold ![]() Nissan S13 S14 KA24DE(Duel Cam Only) T25 Bottom Mount Turbo Manifold ![]() Nissan S13 S14 SR20DET T25 Bottom Mount Turbo Manifold ![]() Nissan S13 S14 SR20DET Turbo Downpipe ![]() Nissan S13 89-94 & S14 95-98 SR20DET Catback Exhaust ![]() Nissan S13 89-94 SR20DET Carbon Catback Exhaust Nissan S13 & S14 SR20DET Fuel Rail ![]() Nissan S13 SR20DET Engine Damper ![]() For RB25 Swap!! RB25 Intake Manifold Three Style Available Cast, Polished , Chromed Cast ![]() ![]() Polished ![]() Chromed ![]() RB25 Fuel Rail Fit 10.5 to 11 mm feed injectors ![]() PM US or CALL US For Better Pricing!!! Let Us Know You are From Zilvia.net for Best Discount!!!! We are S13/S14 Specialist, if you cant find what you need check out our website GodSpeed Project - Intercooler, Turbo Kits, Turbo Manifold, Body Kit or give us a call if you have any question!! We also have other GB on the forum, so please check them out!!! Ken @ Fatboy Garage Motorsport 11135 Rush St Unit B South El Monte CA 91733 626-442-3988 Last edited by Fatboy Garage; 07-20-2009 at 04:11 PM.. |
#14 |
im looking for a top mount manifold... which do you recomend???? log or tubular?? pm me the price. i need a good STRONG ONE PLEASE LMK ASAP
