Old 07-21-2009, 03:00 PM   #1
frankenfresh
frankenfresh's Avatar
frankenfresh is an unknown quantity at this point
tuning the motor, how high should rev limit be?
I've been working on my car for some time now and its almost getting to the point of being all back together and getting tuned. the question is when I have it tuned and a new rev limiter set, how high should it be? I'm told that with my upgraded cams, valve springs and rocker arm stoppers I should be able to rev quite a bit higher. my set up is:
sr20det, 5spd
hks ssqv (welded onto the cold side)
nismo 550 injectors
z32 maf
blitz filter
s15 t28
ss turbo lines
megan exhaust manifold
megan turbo elbow
megan down pipe
greddy profec b
greddy front mount intercooler
wlabro 255 fuel pump
BC 264 cams
Brian Crower Valve Spring & Ti Retainer Kit (i think its BC200 or somthing)
rocker arm stoppers
greddy adjustable cam gears
power fc ecu
light weight pulleys
spitfire ignition system and coils
Circuit Sports Magnetic Oil Drain Plug
NGK Iridium IX Spark Plug, 7 Heat Range
Wix Z32 Fuel Filter
ISIS Intake Manifold
ISIS underdrive Crank Pulley
Peak Performance Thermal Intake Manifold Gasket
sard fuel presure regulator
fuel presure gauge
2.5" hot pipe
2 12" fans
adjustable fan controller
3" aluminum rad
nismo thermostat
bigger oil pan
oil cooler
new front timing cover and oil pump
front main seal
new oem timing chain
revised chain guides
new lower cam chain sprocket
new cam chain tensor
F1 stage 3 clutch
fidanza 9.5lb flywheel
driveshaft shop aluminum 1 piece drive shaft
nismo 2way diff
300zx axles
plx wide band and guage
engine torque dampner
frankenfresh is offline   Reply With Quote
Old 07-21-2009, 04:21 PM   #2
holemilk00
holemilk00's Avatar
Trader Rating: (33)
holemilk00 is a jewel in the roughholemilk00 is a jewel in the roughholemilk00 is a jewel in the roughholemilk00 is a jewel in the roughholemilk00 is a jewel in the roughholemilk00 is a jewel in the roughholemilk00 is a jewel in the rough
Feedback Score: 33 reviews
That turbo will run out of efficiency way before you over rev that motor, a good tuner will see when you are out of your power band, and set the limit just above that (about 1000RPMS) but you should note where your power band is, and keep that in mind when shifting.
I had a cool signature
holemilk00 is offline   Reply With Quote
Old 07-21-2009, 04:49 PM   #3
Grenade180sx
Grenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfection
Send a message via AIM to Grenade180sx
^ true sr stock limiter is what 7200? i say maybe 7800ish and ull be good
Grenade180sx is offline   Reply With Quote
Old 07-22-2009, 09:52 PM   #4
frankenfresh
thanks a lot
