Old 04-19-2003, 11:34 AM   #1
drifties151
drifties151's Avatar
drifties151 is an unknown quantity at this point
Send a message via AIM to drifties151
Question Removing Airbag on 95 240sx se
i searched and only found a thread for the driver side, which i did already. I want to remove the passenger side airbag... i thought i could do it by dropping the glove box down and accessing the airbag through that way. I can access the airbag like that but i don't see any bolts to remove it. any help would be appreciated, thanks in advance.
-terry
drifties151 is offline   Reply With Quote
Old 04-19-2003, 11:47 AM   #2
syco3d
syco3d's Avatar
syco3d is an unknown quantity at this point
Send a message via AIM to syco3d Send a message via Yahoo to syco3d
Try an ax.
Yeah, an ax should do the trick.
If not, then just go balls out w/a chain saw.
EDIT: The author of this worthless post owns a S13, hence the lack of usefull information.
Gimme a "A"!
Gimme a "P"!
Gimme a "C"!
What does that spell?
CRAP!
syco3d is offline   Reply With Quote
Old 04-19-2003, 04:14 PM   #3
indysilvia
indysilvia is an unknown quantity at this point
You'll have to take off the dash which is a lot easier than it sounds. you'll also need the same torx security wrench that you used to take off the steering wheel airbag
indysilvia is offline   Reply With Quote
Old 04-19-2003, 09:07 PM   #4
drifties151
thanks alot indy, i was afraid of hearing that i had to take off the dash... after looking at it, it doesnt seem that hard. thanks once again.
Old 04-20-2003, 06:42 PM   #5
sxfro
sxfro is an unknown quantity at this point
Send a message via ICQ to sxfro
Try an ax.
roflmao.
you can take it out under the dash you have to take the glove box completely out and get a light and get up in there and you'll see what you need to get it out.why the hell are you taking it out anyway.thats not a very smart thing to do
sxfro is offline   Reply With Quote
