Old 08-18-2009, 09:50 PM   #1
ichibans13.5
ichibans13.5's Avatar
ichibans13.5 has made poor choicesichibans13.5 has made poor choicesichibans13.5 has made poor choicesichibans13.5 has made poor choicesichibans13.5 has made poor choicesichibans13.5 has made poor choices
Full s13 Rear Subframe-Helical-Nismo-Por 15-MR
Rear Subframe
I have up for sale a s13 rear subframe that was stripped down by sand blasting- then coated in POR 15 -a bad ass rust resistant coating (look it up). These components were never driven on just installed and aligned by eyeball but car was never finished- some of the blue paint lost some of its shine or chipped a little from adjustment and then taped up to protect
$1000 Firm Picked Up Right Outside Worcester MA
Nismo Subframe bushings pressed in
Full adjustable suspension components with megan racing adjustables
Megan racing rear adjustable traction rod-
Megan racing rear adjustable lower toe arm-
Megan racing rear upper camber arm
New OEM camber bolts
Energy Suspension Red Poly bushings installed
S15 Helical Rear Diff with brand new Output shafts installed and Shimmed with backlash set by DSG (dent sport garage) then the rear cover was polished, a new oem rear diff gasket was intalled and filled with motul fluid
ichibans13.5 is offline   Reply With Quote
Old 08-24-2009, 09:04 PM   #2
ichibans13.5
bump it up
Old 08-29-2009, 03:32 AM   #3
Nacho_240
Nacho_240's Avatar
Trader Rating: (36)
Nacho_240 is an unknown quantity at this point
Feedback Score: 36 reviews
If you're willing to separate and ship, I'm interested in the s15 hlsd.
What ring gear bolts did you use to install the s15 helical diff? LMK how much for the diff + pumpkin + half shafts shipped to 92801. TIA
Nacho_240 is offline   Reply With Quote
Old 08-29-2009, 10:01 AM   #4
ichibans13.5
nacho i will check shipping charges after i weight it and pm you- i brought my pumpkin to dent sport garage and they installed the diff and ordered the shims- so i would have to check with them on the ring gear bolts
Old 08-29-2009, 01:55 PM   #5
Souljahzs13
Trader Rating: (66)
Souljahzs13 is an unknown quantity at this point
Feedback Score: 66 reviews
If Nacho 240 bails, pm me on how much for the helical diff/w output shaft shipped to 90650 thx
Souljahzs13 is offline   Reply With Quote
differential, helical, nismo, subframe
