![]() Join Date: Aug 2008
RB20DET Not Starting
OK
Specs 91 240sx Rb20det (stock) Picked car up already swapped ![]() All the motor will do is Crank crank crank crank and not start not even a sputter or anything What i checked and fixxed when this started happening 1.Wire harness was all Messed up so i think i fixxed it 2. CAS was bad so replaced New Used one Tested and works on other Motor 3. ECU was good but got Another unit just in case Both ECU was checked and work perfect 4. Check all relays and fuses all bad was replaced 5. Check all Grounds on Motor and ECU and i added some more grounds 6. Check Fuel pump (255 walbro) primes and works perfect fuel PSI is OK 7. Coils and Injectors are working you think it mite the key switch on steering column? I cant Figure this out and driving me crazy Last edited by nurvcom; 09-01-2009 at 02:13 PM.. |
#8 |
#12 |
ok check fuel line It hook up right still not starting Took A compression test
Front 6 130psi Front 5 130psi Mid 4 130psi Mid 3 130psi Rear 2 140psi Rear 1 140psi ok Pulled coils and checked them agine each coil fires fine and injectors working fine cuss it floods after 5 or 6 time trying to start it Half Mood (F#$King) Key Broke off cam so now it kinda hard to reinstall cas ![]() and it still not starting well I think i going to fuxking give up it not whatting to work and i put so much into now i am pissed ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
#13 |
you have not checked the battery or starter yet?
mine was giving me issues as well. check the starter clip. the connector that is probably loose or is not making contact. i had to redo mine because it would not start at all. i also had an odyssey battery that died on me, bought a stock one that would fit in the engine bay and i haven't had issues as of lately. don't give up!
neg repping is cool!! ![]() |
#14 | |
Ok battery is Good holding over 12.something volt and i am wearing it down recharging it to keep working on it ok starter Clip? Starter not loose it crank crank cranks cranks when battery low it crank crank stop crank crank stop crank |
#16 | |
not the picture i was looking for, but it is too dark out for me to take a picture to show you. you have the bolt for the ground and the male pin for the power. the female connector is what possibly could be loose or not making a good connection, if it is on there and you have a butt connector, that could be your issue to. my butt connector was not crimped down good enough and it pulled right off. i forgot what i gapped mine to. i believe it is .037 inches, but do not quote me on that ![]()
#17 | |
ok i guess it some it some kinda of signal wire to tell ECU car is starting or something sorry if i Sound Stupid i usally Good with cars it just this motor that got me I am a honda guy i still have a 95 RHD civic coupe with a built b18B LS swap ![]() i guess your close i did a search and found tons of people on nico and here using this gap on rb20 and rb25 .032 |
#18 | |
I am a Honda guy myself. 2002 Civic Hatch with Greddy kit and I am nearly done building another motor (K20a2) ![]() What plugs did you buy? I was told to buy the 300zx Turbo spark plugs.
#20 |
Crank Sensor?
My Honda's Crank Angle and Cam Sensor went out and the car wouldn't do crap...wish you had a video or if i was close enough i could look at it at least...lol
#23 |
hopefully if i can get my camera working i take a video
Any new ideas on what Should i check ??? my motor is somewhat apart Coil and plug pulled I checked all vac Does Fuel rail have 2 FPRs? one on each end ? Everyone when i Got this car it ran and started only 5 time ![]() i got it with rb20det already swapped into car... What I have Done in parts harness repaired new used cas other one was bad new plugs new used ECU how many sensors are on the rb20det? Would any sensor make the car not start??? all it does it crank over but no sputter or coughing at all!!! |
#24 |
![]() Join Date: May 2006
Proper gap is ~.030", so that's not the problem.
The wire you're looking for is orange with silver hash marks from the dash harness (I assume it's an S13), and goes to the ECU to give +12V whenever you're cranking the car. The car should start without it, if you pump the gas and crank it a few times, so I'm guessing that's not the problem. Anyway, check to make sure you have +12V at all the applicable pins using the wiring diagram: ![]() The pin locations are from THE BACK of the ECU harness most of the time - you can check because the '100' pins are physically larger than the rest.
#25 | |
YA ECU red light go's out when cranking car that should stay on? meaning that ecu stay's on |
#26 |
My guess is you've got your ECU wiring wired up directly to the ignition switch, and you're using an 'Accessory' wire instead of the black/white (or black/red, depending on where you grab it) 'Ignition' wire. Use a multimeter with a probe on your "ignition-switched +12V" leads on the ECU, see if they drop to no volts while you're cranking.
#27 | |
well My multimeter stopped working ![]() and check wire it looks good to my eyes Man this car is first to discourage me ![]() ok i talked to the guy who use to own the car with rb20det he swapped it in He said it was working find and all of a sudden it just died and didn't what to start and he only got it to start a few time after and i got it to start a few time to ![]() Last edited by nurvcom; 08-31-2009 at 06:02 PM.. |
#28 |
U think it Could be my harness got a problem?
i tryed to change some wires and it still doesn't start only crank crank ![]() This car would start every once and wile and run but once warm it would Die ![]() |
#29 |
All the information you need to diagnose the problem is in this thread.
Once you figure out where the problem is, I will try and give you some tips on how to fix it.
