Old 11-20-2009, 08:54 PM   #1
1quk240
Banned from the Marketplace
1quk240 will become famous soon enough1quk240 will become famous soon enough1quk240 will become famous soon enough1quk240 will become famous soon enough
s13 sr20 wont start
1. The motor is cranking but im not getting any spark?
2. And for some reason the fuel pump is not priming? I had to hard wire it to the battery to turn on. not really a bad thing i guess cuz then i can just run a cut-off switch to it.
anyone with any info on these two problems please chime in. thanks
1quk240 is offline   Reply With Quote
Old 11-20-2009, 09:25 PM   #2
hottscennessey
hottscennessey's Avatar
hottscennessey is an unknown quantity at this point
fried ECU?
I think by hardwiring the fuel pump you eliminated any fuel issues... the ECU would normal control the FP.
Did the car start doing this all of a sudden, or has it ever run?
hottscennessey is offline   Reply With Quote
Old 11-20-2009, 09:28 PM   #3
1quk240
Originally Posted by hottscennessey View Post
fried ECU?
Just all of the sudden. I took it out of my previous car and put it into another hatch. I check the ECU and it looked good, nothing fried or broken. i just dont know why the ecu isnt turning the fuel pump on
Old 11-20-2009, 11:47 PM   #4
Ceepo
Ceepo's Avatar
Ceepo will become famous soon enoughCeepo will become famous soon enoughCeepo will become famous soon enoughCeepo will become famous soon enough
are all the fuses good?(i know thats a gimmie but always check them)
Ceepo is offline   Reply With Quote
Old 11-20-2009, 11:59 PM   #5
1quk240
yeah. first thing i checked
Old 11-21-2009, 12:10 AM   #6
Joey89s13
Joey89s13's Avatar
Joey89s13 is an unknown quantity at this point
make sure the fuse boxes are all bolted up tight.. you never know coulda come loose
Joey89s13 is offline   Reply With Quote
Old 11-21-2009, 12:33 AM   #7
1quk240
Yeah there pretty secure. But wouldtgat be a reason for the coils nit getting any spark?
Old 11-21-2009, 12:47 AM   #8
Ceepo
Ceepo's Avatar
check the ignitor chip, also the ground for the coilpack sub harness...
Old 11-21-2009, 01:21 AM   #9
1quk240
How can i check if the ignitor chip is bad? It should be good the motor was running when i took it out of my car. The ground for the coilpack is to the head then from the head to the chassie. also from my intake manafold to the firewall
