Old 12-03-2009, 12:47 AM   #1
sc0braj
sc0braj is an unknown quantity at this point
electrical problem!
first i would like to say i'm new to this forum, but i have been in manyyy other forums so i basically know the rules.. so i have a 89 s13 coupe with a red top sr20det swap.. interior is completely stripped(exposing all the metal) and there are some uncovered wires.. so anyways i drove to a friends house and stayed for about 10 min then i switched the car into the acc. mode. the lights come on for a quick second, then all the sudden everything is completely dead! i mean DEAD. i tried jumping the battery but still nothing would turn on.. including digital clock, headlights, brake lights, dome light or the door lights.. im thinkin i might've blown the ecu fuse or maybe the ecu itself?!? i hope its just a fuse if there even is one... so its parked infront of my friends house until i get help to figure the problem out.. please let me hear your ideas!
sc0braj is offline   Reply With Quote
Old 12-03-2009, 01:08 AM   #2
sc0braj
bump! basically the car acts like it doesnt have a battery in it at all, but the battery is good no doubt about it.
Old 12-03-2009, 01:25 AM   #3
SoguRacing
SoguRacing's Avatar
SoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfection
Send a message via AIM to SoguRacing
check out your ignition relay or starter relay.
Pre Tune Checkup! Compression,LeakDown,Vacuum Test $80. Cams Install: $180
SoguRacing is offline   Reply With Quote
Old 12-03-2009, 01:57 AM   #4
sc0braj
theres no power at all from the battery to anything!!! that doesnt seem like a starter or ignition relay problem. the car cant even crank to know if i have a bad starter or ignition relay. lol
Old 12-03-2009, 02:08 AM   #5
ForcedNduction
ForcedNduction is an unknown quantity at this point
Check your battery terminals for corrosion then check all of the connections coming off the positive terminal.
ForcedNduction is offline   Reply With Quote
Old 12-03-2009, 12:45 PM   #6
fcdrifter20
fcdrifter20's Avatar
Trader Rating: (44)
fcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to behold
Feedback Score: 44 reviews
it wont if u got a bad ignition relay or fuse. dbl check all those then check ur main battery ground and make sure that is bolted down properly. make sure that the battery you're using is good and hasn't leaked anywhere.
fcdrifter20 is offline   Reply With Quote
Old 12-03-2009, 10:00 AM   #7
slider2828
slider2828's Avatar
Check your fuses.....
Turn and Burn!
Old 12-03-2009, 12:58 PM   #8
SoguRacing
SoguRacing's Avatar
check your ground from your battery to your engine block.
Old 12-03-2009, 02:11 PM   #9
sc0braj
fixed! somehow the ground wire from the battery shorted out.. bought a battery cable from kragen n she started right up.. lovely!! thanks guys
