![]() Join Date: Jan 2005
![]() ![]() ![]() ![]() ![]() Feedback Score: 8 reviews
car twiching ??(s14)
driving home i notced my s14 pulls hard to the left or right at random times. i cant figure out hy, it twitches randomly, it pull hard to ither direction for a couple of seconds then when i let off the gass it stops after i slow down.. it doesnt happen all the time but every so often it occurs..
it feels more like the right side of the car is doing it more then the left.. could it be due to worn tie rod ends? it kinda feels like what happens when your toes is off. idk any help will be appericated. btw car is a 97 s14 / megan coils. idk if that makes a difference..
s14 kouki ka-t |
![]() Join Date: Oct 2004
Worn tie rod, ball joints, lower arms, tired rack bushings or a shifting rack or a loose subframe will do that to you.... Alignment as well. Check all of them...
![]() Join Date: Nov 2007
Trader Rating: (44)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 44 reviews
he is right anyone of theese will cause it. double check all those and make sure the bolts on everything is tight, i have had a couple occasions shere i have seen ppl install some parts and have similar problems, and it was due to them leaving something loose or not putting it on rite
#4 | |
![]() Join Date: Apr 2009
Trader Rating: (38)
![]() Feedback Score: 38 reviews
ya what those 2^^ said, ive also noticed it can happen from the tires wearing unevenly, happened to me quite a few times after some drift nights |
#5 |
hmm took a look under my car and saw this
(excuse my ms paint drawing) ![]() the inner tie rod doesnt seem to be bent but its not level with the rack its going on a incline upward, idk why. wierd. any suggestions?
s14 kouki ka-t |
#6 |
AFC #1
![]() Join Date: Oct 2003
It's not level cause you are lowered.
Probably need to replace your tie rod ends at the minimum. May want to get ones with spacers to make them level again. http://www.splparts.com/main4/parts/...k.htm#Steering After you replace get an alignment. Deathwobble is not called such cause it is something you can ignore.
#8 |
Super Moderator
![]() Join Date: Jun 2004
Trader Rating: (73)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 73 reviews
It may be a bent suspension component, maybe one side of your car is lowered more than the other.
I would start with replacing the tie rods inner/outer first. They're probably worn and have play in them.
![]() Best way to do business with me? Make your best offer FIRST. |
#9 |
There is no why really... LOL so funny... it just happened.... anyways, you just need to get it fixed. check alignment and they will tell you what is wrong....
