Old 12-15-2009, 11:15 PM   #1
gotboost2jz
gotboost2jz's Avatar
gotboost2jz is an unknown quantity at this point
tachometer problems
95 240sx
My tachometer is completely wacked out. It does not read the proper RPM. I'll turn the car on and at idle it will bounce between 3k and 6k and continue to do so while I accelerate. Every once in a while it drops into range but eventaully resumes bouncing everywhere again. It's completely unpredictable. The speedometer also doesnt work but that's only because i have yet to change out the speed sensor to the US unit.
Is it bad wiring, or do I need a new dash cluster altogether?
1995 240sx SE - 1JZ
gotboost2jz is offline   Reply With Quote
Old 12-15-2009, 11:17 PM   #2
Rabboni
Rabboni is an unknown quantity at this point
I cant be sure, but it sounds like you have some crazy wiring gremlins to chase
Baling Wire-The Duct Tape Of Champions
Rabboni is offline   Reply With Quote
Old 12-16-2009, 08:42 AM   #3
Dream240
Dream240's Avatar
Dream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond repute
The tach gets it's signal from the ecu (terminal 3). So if you've got a tach problem, start tracing the wiring from there to the tach in the gauge cluster. If the wiring is good, then replace the tach unit.
The tach signal is not in any way connected to the speedo sensor. The only association is that they both use wires coming from the same harness connectors that plug into the cluster, but that's it.
Don't mess with my monkey...he's loaded.
Dream240 is offline   Reply With Quote
Old 12-16-2009, 10:52 AM   #4
g6civcx
g6civcx's Avatar
What engine is in the car?
You can try connecting a service tach and check the output signal. If the service tach also jumps around then the problem is in the sender.
If the service tach works fine then the problem is in your wiring.
Old 12-16-2009, 11:37 AM   #5
gotboost2jz
its an s13 sr
i'll just check the wiring when i return stateside. is it possible it could be a bad feed from a plug to the ECU?
1995 240sx SE - 1JZ
Old 12-16-2009, 11:46 AM   #6
g6civcx
g6civcx's Avatar
Originally Posted by gotboost2jz View Post
its an s13 sr
Either that or the ECU and/or cluster is bad.
Old 02-01-2010, 11:28 PM   #7
afiser
afiser is an unknown quantity at this point
i have the same problem, where is the rev sensor located? i wanted to check the wiring from the sensor to the ecu but im kinda clueless where to start.
afiser is offline   Reply With Quote
