Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Advertiser Specials and Sales > Suspension
Old 01-15-2010, 03:28 PM   #1
IMPORTIMAGE
IMPORTIMAGE's Avatar
Trader Rating: (78)
IMPORTIMAGE is an unknown quantity at this point
Feedback Score: 78 reviews
Send a message via AIM to IMPORTIMAGE
Talking Fortune Auto and BC Racing Coilovers @ Import Image!! Great deals inside :D
CALL 804-690-2452 or 239-540-6385 MENTION BILLY to receive special pricing ON ZILVIA!!!!!
Zilvia, We are now the Master Dealers of Fortune Auto coilovers!
Price:Fortune Auto 500 Series $999 Shipped to your door! (PM for best price)
PRICES ON FORTUNE ARE GOING UP MARCH 1ST GET THEM WHILE YOU STILL CAN BEFORE THE PRICE INCREASE!!!!!!!!!
All coilovers incorporate a 50mm piston, 30 way damping, fully anodized body, custom rates & a 1 year warranty. This rigorous testing has earned us our ISO certification. Furthermore we incorporate features only found on our coilovers such as Seamless stainless steel monotubes, Forged lower mounts & proprietary nitrogen gas chambers.
Features:
* Dyno tested***
* Stainless steel body / piston
* 30-way adjustable dampers
* Pillowball mounts
* Forged aluminum locking collars
* Dust boots on all pistons
* 50mm piston (beyond the industry standard of 44-47mm)
* Anodized aluminum camber plates** on front upper-mounts
* Fully anodized body
* 1 year Manufacturer's Warranty
* Height adjustment independent of preload
* ISO 9002 certification
Every Fortune Auto coilover is extensively dyno tested and matched with in specifications to insure a consistent and uniform set of coilovers. This rigorous testing has earned us our ISO certification.
These Coilovers go LOW!!!
Custom Spring Rates!! Done in the U.S.A!
(95KA-Turbo on Zilvia)
We are also the #1 Vendor in the nation for BC Racing coilovers!
BC Racing BR series Coilovers $999 Shipped!! Free Custom Spring Rates as well!!
Our BR model is perfect for street driving and occasional road course duty. With easily accessible adjustment knobs for fine tuning your compression/rebound and separately adjustable ride height, having a performance coilover system couldn’t be any easier. You choose how low or high you want your vehicle, no preset ride height here, and our patented concave lower locking ring keeps it locked in. All of our systems come with pillowball mounts to provide the most feedback possible from your suspension and to sharpen your steering response. BC’s available front and rear camber plates also allow you to get the perfect alignment setup without compromise. All this while providing a strong, attractive looking coilover system.
- Mono-tube shock design
- 30 levels of damping force adjustment, adjust compression/rebound
- Pillowball mounts and adjustable camber plates included (where applicable)
- Adjustable rear camber plates available
- Separate full length height adjustable
- One year warranty
- Rebuildable
Technical
- Coilovers use 46mm pistons and 53mm shock housings, the enlarged shock cartridges with specially designed pistons and rods provide a wide range of damping force.
- Valves are constructed of special spring steel, which outperforms stainless steels and produces longer valve life. Valve stacks use a patented deflective system to provide more precise control.
- Patented concave lower locking ring, to prevent unseating.
- Springs are made of SAE9254 high strength, durable steel. Compression tested at over 500,000 tires with less than 5% deformation.
- T6061 Aluminum utilized in spring locks and seats for high strength and lightweight.
- Iron lower brackets on MacPherson struts to ensure rigidity.
- Piston rods are constructed of highly polished steel to lengthen oil seal life and prevent leaking.
- High pressure inner rod guide seals ensure a perfect fit for consistent fade resistant damping and long shock life.
- 2 step coating process utilizing nickel and chromium plating to prevent corrosion.
- Newly developed lubricant oil in shock cartridges minimizes aeration and cavitation.
- An additional bearing beneath each pillowball mount provides the smoothest action and prolongs the lifetime of the pillowball itself.
BC Racing RAM type (Inverted) $1225 Shipped!!!
BC Racings inverted RAM model includes all of the great BR features and then takes it a notch higher. By using an inverted coilover system we move the vital damper fluid away from the detrimental heat sources to avoid overheating the fluid and causing damper fatigue under extreme conditions. The inverted setup also handles high-g loads better and is much more durable under stress situations, such as a race track. Another advantage is reducing unsprung weight by moving the heavy parts to the chassis mounting points. This is a great coilover for those looking to attack a race track, hill climb or tarmac rally.
- Inverted Mono-tube shock design
- One year warranty
- Rebuildable
BC Racing ER series $1850 shipped!!
Our newest and most advanced model yet is the ER series coilover. It features large external reservoirs front and rear, separate rebound and compression adjustment and a twin piston design. The external reservoirs hold much more oil than the conventional coilover, allowing the coilover to operate for a much longer period of time before overheating. The external reservoirs also house the secondary piston, which allows for the fine tuning of compression. This is the perfect coilover system for the person who wants to fine tune there setup using the separate, 30-way, rebound and compression tuning dials.
- External Reservoir Mono-tube shock design
- 30 levels of damping force adjustment, adjusts both compression and rebound separately
- Twin piston design
- One year warranty
- Rebuildable
Josh Nahm
Import Image Racing Your Online Source for Aftermarket High Performance Car Parts and Accessories for Subaru WRX and STI, Nissan, Mazda, Misubishi Evolution and others.
239-540-6385 visa/mc
227 sw 3rd ave
Unit 100
cape coral, FL 33991
paypal confirmed to [email protected]
Questions: Billy (804)-690-2452
(email)[email protected]
AIM- importimagebilly
IMPORTIMAGE is offline
Old 01-15-2010, 08:13 PM   #2
MemphisSlideways
MemphisSlideways is an unknown quantity at this point
Best price on fortune autos for s13 shipped to 38018 and paypal info
MemphisSlideways is offline
Old 01-15-2010, 11:51 PM   #3
drifter_for_life06
drifter_for_life06's Avatar
drifter_for_life06 is making a name for him/her selfdrifter_for_life06 is making a name for him/her self
Send a message via AIM to drifter_for_life06 Send a message via Yahoo to drifter_for_life06
Price on Fortune for s13 shipped to 17363 please
RPS13: +.020" 2871r 264's AEM EMS
http://enjukuracing.com/#_l_4s
drifter_for_life06 is offline
Old 01-16-2010, 12:34 AM   #4
hassanbakar123
hassanbakar123 is an unknown quantity at this point
price on fortune coils for s14 shipped to 92404
hassanbakar123 is offline
Old 01-16-2010, 01:57 AM   #5
juicyjay
juicyjay is an unknown quantity at this point
any coilovers for 06 350z? :x
juicyjay is offline
Old 01-16-2010, 06:20 AM   #6
kouki-gymkhana
kouki-gymkhana is on a distinguished road
Best price on fortune 500 series coilovers for s13 shipped to 33156? Thanks!
**The atypical S-chassis enthusiast***
kouki-gymkhana is offline
Old 01-16-2010, 10:24 AM   #7
IMPORTIMAGE
Trader Rating: (78)
All PM's Replied
Old 01-16-2010, 10:25 AM   #8
Project "Rojo" s13
Project "Rojo" s13's Avatar
Project "Rojo" s13 is making a name for him/her selfProject "Rojo" s13 is making a name for him/her selfProject "Rojo" s13 is making a name for him/her self
Best price on fortune 500 series coilovers for s13 shipped to 75040? Thanks homie!
Ricer: Any car which was designed to go slow and modified to even go slower
Project "Rojo" s13 is offline
Old 01-16-2010, 05:19 PM   #9
Zero-Offset
Zero-Offset's Avatar
Zero-Offset is an unknown quantity at this point
Price on the fortune auto coils for s13 to 98230.
Thanks!
Zero-Offset is offline
Old 01-16-2010, 08:06 PM   #10
airforceone451
airforceone451's Avatar
airforceone451 will become famous soon enoughairforceone451 will become famous soon enoughairforceone451 will become famous soon enoughairforceone451 will become famous soon enoughairforceone451 will become famous soon enough
fortune auto coilovers for s14 shipped to 27511? thanks!
airforceone451 is offline
Old 01-17-2010, 03:25 AM   #11
cooltomato
cooltomato is an unknown quantity at this point
may i please get the best price for the fortune autos for the s13 shipped to 94132? and how long will this deal last?
cooltomato is offline
Old 01-17-2010, 05:30 PM   #12
IMPORTIMAGE
Trader Rating: (78)
Thanks!
All PM's replied.
Keep them coming!!!! You won't be disappointed
Old 01-17-2010, 08:46 PM   #13
jonski coupe
jonski coupe is an unknown quantity at this point
Price on Fortune 500's shipped to 86503. Thanks.
jonski coupe is offline
Old 01-18-2010, 11:17 AM   #14
IMPORTIMAGE
Trader Rating: (78)
Replied and to the top!
Old 01-18-2010, 11:44 AM   #15
diamonddrift
diamonddrift's Avatar
diamonddrift has a little shameless behavior in the past
price on fortune 500 s13 73135
diamonddrift is offline
Old 01-18-2010, 12:34 PM   #16
BlueKpS13
BlueKpS13's Avatar
BlueKpS13 is a name known to allBlueKpS13 is a name known to allBlueKpS13 is a name known to allBlueKpS13 is a name known to allBlueKpS13 is a name known to allBlueKpS13 is a name known to allBlueKpS13 is a name known to allBlueKpS13 is a name known to allBlueKpS13 is a name known to allBlueKpS13 is a name known to allBlueKpS13 is a name known to all
any love for FCs?
BlueKpS13 is offline
Old 01-20-2010, 09:24 AM   #17
IMPORTIMAGE
Trader Rating: (78)
PMed
Originally Posted by BlueKpS13 View Post
any love for FCs?
Yes!
and
UP to the top!
Old 01-21-2010, 11:01 AM   #18
IMPORTIMAGE
Trader Rating: (78)
to the top with Fortune and BC!
Old 01-21-2010, 04:36 PM   #19
iwannaslyde
iwannaslyde's Avatar
iwannaslyde is an unknown quantity at this point
price on fortune coilovers shipped to 34758
iwannaslyde is offline
Old 01-22-2010, 12:39 PM   #20
IMPORTIMAGE
Trader Rating: (78)
All PM's replied
Old 01-25-2010, 01:58 PM   #21
IMPORTIMAGE
Trader Rating: (78)
Getting closer and closer to track season! Get your coilovers!!
Old 01-26-2010, 07:17 AM   #22
Alan_405
Alan_405's Avatar
Alan_405 is on a distinguished road
any military discounts on the Fortunes
Alan_405 is offline
Old 01-26-2010, 08:46 AM   #23
IMPORTIMAGE
Trader Rating: (78)
PMed
Bringing this to the top!
Old 01-27-2010, 05:26 PM   #24
Beast Mode the 240
Beast Mode the 240 is an unknown quantity at this point
Best Zilvia pricing shipped on fortune 500 to 94087. Thanks.
Beast Mode the 240 is offline
Old 01-28-2010, 02:32 PM   #25
IMPORTIMAGE
Trader Rating: (78)
PMed!
These coilovers are FLYING off the shelves!! Get your for this next track season
Old 01-30-2010, 09:34 PM   #26
t0psec12etpanda
t0psec12etpanda is an unknown quantity at this point
sent you a pm on the fortune auto 500
t0psec12etpanda is offline
Old 02-05-2010, 10:12 AM   #27
Alan_405
Alan_405's Avatar
Just purchased my set 2 min ago
WOOOOO HOOOO
Alan_405 is offline
Old 02-07-2010, 02:17 PM   #28
IMPORTIMAGE
Trader Rating: (78)
PMed back!
WOOOOO HOOOO
WOO HOO is right!! Enjoy them I know you will
Old 02-08-2010, 09:05 PM   #29
FNR32
FNR32 is an unknown quantity at this point
price on fortune coilovers shipped to 35206
FNR32 is offline
Old 02-09-2010, 02:58 PM   #30
d-wade
d-wade is an unknown quantity at this point
Price for Fortune Auto S14 coilovers shipped to 17225?
d-wade is offline
