![]() Join Date: Jul 2001
![]() I have an s14.
How do you know if a certain wheel will be able to clear coilovers? How about these wheels: 17x8j with offset +34 and 17x9j with offset +38?
Drifting is just a compromise between you and your car. |
![]() Join Date: Jun 2002
![]() ![]() ![]() ![]() Feedback Score: 2 reviews
here u go buddie..From FreshAlloy posted by Mav1178
""...Wheels/hubs -Clearance of wheels for Z32 brake upgrade is entirely dependent on wheel spoke AND wheel design, NOT on offset of wheel. -Wheel width/offset needed for clearance of coilovers is as follows (disregarding brake clearance): 6" +54 or lower 6.5" +45 or lower 7" +40 or lower 7.5" +34 or lower 8" +30 or lower 8.5" +24 or lower 9" +20 or lower Please note that this does not take into account variations in offset calculation by manufacturer, or tire sidewall bulge. This list also does not take into account differences in design of coilovers (esp. lower brackets on coilover kits which can cause changes in wheel clearance issues). This list also only applies to the FRONT WHEELS and is intended as a GUIDE for reference. -The LARGEST wheels that will fit the front of a S13/14 with stock fenders is 9" wide. The rear can take up to 10.5" wide with a very specific offset AND must dial in negative camber. To fit large wheels one must use negative camber to ensure proper fender clearance." |
![]() Join Date: Sep 2002
Location: Athens/Chattanooga/ Cookeville/Morristown, TN
wow, i didn't realize that with 9" you needed that low of an offset with coilovers... does anyone have a pic of 9's with coilovers? because that is what i was planning on getting... sorry didnt mean to steal your thread
89 240 SR powered... ummm i promise its stock ![]() |
![]() Join Date: Apr 2002
17x9 with +25 clears coilovers. Dorifuto has that setup and it clears (but just by a tad).
Swap DONE: 40K Redtop, Greddy Turbo extension, Greddy DP, Greddy V-SPL FMIC, Greddy Hotpipe, HKS SSQV, Koyo Radiator, Toda Ultralight FW, Spec Stage 2 Clutch, ATS 2-way Diff., Rice-Boy Red Air Filter. |
#6 | ||
Re: fender flares?
in other words. u can fit those widths with stock fenders as long as the offsets are good and that u run negative camber. and fender rolling isnt a bad idea either. |
#7 |
more specific
i should have been more specific: with tires that wide do they stick out beyond the fender? i assume you can have a tire/wheel combination that physicaly fits in the wheel well but sticks out past the fender. im just wondering how far.
HB |
