Old 02-10-2010, 04:43 PM   #1
junn
junn's Avatar
junn is an unknown quantity at this point
anyone with a LS1????
im almost done with my build....got my engine put together and all the little stuff ready....but wanted to know if anyone had any suggestions for gear ratio
one of my buddies is a long time camaro guy and he told me best gears he had were 3.70...he enjoyed all his gears and even downshifted from 6 to 4th with no problems
i wanna enjoy all my gears also...especially 1st
just trying to get some suggestions
thanks
junn is offline   Reply With Quote
Old 02-10-2010, 04:53 PM   #2
vaughn4
vaughn4's Avatar
vaughn4 is a splendid one to beholdvaughn4 is a splendid one to beholdvaughn4 is a splendid one to beholdvaughn4 is a splendid one to beholdvaughn4 is a splendid one to beholdvaughn4 is a splendid one to beholdvaughn4 is a splendid one to beholdvaughn4 is a splendid one to beholdvaughn4 is a splendid one to beholdvaughn4 is a splendid one to beholdvaughn4 is a splendid one to behold
It depends on which transmission you are using. I am using a 00 WS6 T56, MM6, with the stock 4.08 and I love it. However if you are running a T56 from a GTO, I would suggest a J30. Here is a chart that I found a long time ago.. should help you understand the differences.
General Motors Corporation Transmission Gear Ratios
Tremec info on Wikipedia
Originally Posted by kalypso123 View Post
for real...
all you need is a fender puller, some zip ties, and a blog.
vaughn4 is offline   Reply With Quote
Old 02-10-2010, 05:05 PM   #3
junn
junn's Avatar
awwwww...nothing came up^^ lol
im running t56 of 2000 camaro ss
Old 02-10-2010, 05:17 PM   #4
vaughn4
vaughn4's Avatar
try those links now.. fixed.
My opinion is just to run your stock 4.08 rear end and get a feel for what you want. It all depends on the owner. Tire size does play a small role in what you will want. I run 275/35/18 and its perfect for me. I feel that I can run through every gear no problem. I mean if I pull to 6500 in 5th its 160mph. I rev to 7200 so its more than I will ever need.
for real...
Old 02-10-2010, 07:00 PM   #5
junn
junn's Avatar
wow not bad...im running 255/40/17
i was considering running the q45 diff off a 97-01 model or 84-86 300zx cause gears are similar
Old 02-11-2010, 05:24 AM   #6
Otto347
Otto347's Avatar
Otto347 is an unknown quantity at this point
T56 with the stock 4.08 but I cant drive it yet
Originally Posted by atutt View Post
Or you could have stopped being a lazy asshat and done some research.
Otto347 is offline   Reply With Quote
Old 02-11-2010, 07:36 AM   #7
mmdb
mmdb's Avatar
mmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymore
Ditch the 4.08. Second gear is useless. 3.69 works well, though if I had the option I'd go lower.
.25 till 3
mmdb is offline   Reply With Quote
Old 02-11-2010, 03:56 PM   #8
junn
junn's Avatar
yea thats the setup i was thinking
