Old 06-13-2003, 02:56 PM   #1
ILiveToDrift
ILiveToDrift's Avatar
ILiveToDrift is an unknown quantity at this point
Unorthodox vs Unorthodox Q's
I know how people say that underdrive pullys will ruin the engine. What if you replaced the Alternator, Power Steering, and Water Pump too. Or what I'm really saying is which would be better just haveing the crank pully or all 4 of them. Or will it even matter. also if I do replace them all will it add more hp, like more than 1hp per pully.
ILiveToDrift is offline   Reply With Quote
Old 06-13-2003, 03:09 PM   #2
West
OMNOMNOMNOM
West's Avatar
West has disabled reputation
Send a message via AIM to West
I honestly in all my years I dont think ive ever seen someones engine get damaged as a direct result of a UD pulley. IIRC Unorthodox dosent make a multi pulley set for the KA, but Greddy makes one for the SR. The best way to go for the KA is to get the ASP UD Pulley for about 120$ +/-. There would be no purpose to replace the Alternator, Power Steering, or Water Pump when you install the UD pulley. IMO it wouldnt help any more then +1 hp if you did the other pulleys anyways, overall the Pulley gives the KA about 3-6 more HP max. Is it worth it? I think it is if you need to do a belt change, get the pulley and put it in there while your down there.
West - Zilvia.net - Toyobaru.net - NapkinSketch.com
West is offline   Reply With Quote
Old 06-13-2003, 03:10 PM   #3
ILiveToDrift
Thanks man. I think I'll go with ASP.
Old 06-13-2003, 03:59 PM   #4
Jim96SC2
Jim96SC2 is an unknown quantity at this point
Send a message via AIM to Jim96SC2
Greddy is NOT an underdrive pully.
Swap DONE: 40K Redtop, Greddy Turbo extension, Greddy DP, Greddy V-SPL FMIC, Greddy Hotpipe, HKS SSQV, Koyo Radiator, Toda Ultralight FW, Spec Stage 2 Clutch, ATS 2-way Diff., Rice-Boy Red Air Filter.
Jim96SC2 is offline   Reply With Quote
Old 06-13-2003, 04:05 PM   #5
West
OMNOMNOMNOM
West's Avatar
Didnt know. So what is it?
Old 06-13-2003, 04:37 PM   #6
Red
Red's Avatar
Red is an unknown quantity at this point
Get the Unortadox set. (400$) off www.enjukuracing.com
12hp gain ( http://www.importtuner.com/tech/0210it_powerpages/ )
EDIT: did not post pic right.
http://www.cardomain.com/memberpage/509537
http://www.imagestation.com/album/?id=4287415487
http://www.zilvia.net/f/showthread.php?t=21036
Red is offline   Reply With Quote
Old 06-13-2003, 04:44 PM   #7
ILiveToDrift
Is it worth the $400? or is $120 for the ASP more reasonable.
Old 06-13-2003, 04:57 PM   #8
Red
Red's Avatar
Well i'm sure the 120$ is more reasonable. I plan to do the 400$ unortadox ones. I'm sure I will never ware them out. I'm not sure if you can buy the other pullys if they arnt in the set.
I bet the ASP will help.. It just comes down to how much you want to spend.
I'm a do it right the 1st time type of guy.
Old 06-13-2003, 05:00 PM   #9
ILiveToDrift
I agree with you there. I want to get all 4 but that will leave me with less money for other mods. I was either going to get a couple expencive mods or go with some ok priced mods but for areas of the car. That counts cosmetic work. I do love the sleeper look but I want my car to still look good.
Old 06-13-2003, 09:56 PM   #10
kandyflip445
kandyflip445's Avatar
Does anyone know why the SET of pulleys is for 95-98 when the crank-only is for 91-98? I was thinking about getting the set for my 91' but was kinda stumped as to why it says those years.
My 240 vBgarage
Old 06-14-2003, 02:18 PM   #11
Red
Red's Avatar
Because from what I have read and heard... Some guy with a 95 nissan 240sx went in and comishend them to make pullys for his race car.. (KA24DE) engine.. So they made some... I'm sure that cost quite a bit.
(Thats what I hear.. Dont kills me if its not true)
EDIT: Not to do with pullys.. But I found a place that if you send them OEM body parts from the manufacture.. they will make a carbonfiber part for it.. Then you can buy.. ohh CF fenders.. I was thinking of doing this.
