Old 06-14-2003, 04:09 PM   #1
misnomer
misnomer's Avatar
misnomer has a little shameless behavior in the past
Send a message via AIM to misnomer
Injector O-Rings
Arrighty, got a fuel leak. It seems to be coming around the backside of the injector (fuel rail side). Tried replacing the O-rings, but the ones I got were kind of loose around the injector's groove, didn't resolve the problem.
Is there a specific way these need to be installed to shrink around, or did I just get the wrong o-rings? I picked these up from Car Quest, where (aside from the stealership) would be a good place to get some new ones?
Rowsdower saves us and saves all the world!
misnomer is offline   Reply With Quote
Old 06-14-2003, 05:01 PM   #2
transient
transient's Avatar
transient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant future
Send a message via ICQ to transient Send a message via AIM to transient
AFAIK, The o-rings will need a little bit of lubricant applied to them to get them to slide on, and also to prime them a bit. I think motor oil does the trick, but i'm not entirely sure.
Learn everything you can, while you still have the chance.
transient is offline   Reply With Quote
