Old 02-19-2010, 01:00 AM   #1
seto519
seto519 is an unknown quantity at this point
wheel fitment help!!
ok so before people start flaming me i did do my search and found nothing on 18x9.5+35. so heres my question would i need spacers to clear my front coils on 18x9.5+35 with -.5 camber. thnx for any help. im tryin to not use spacers in the front. but if i have to i will. if u know wat size spacer i need that will help alot too. thnx
seto519 is offline   Reply With Quote
Old 02-19-2010, 02:34 AM   #2
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Every coilover is different as far as strut design and over all diameter. Safe bet is 15mm spacer to clear the strut...maybe as small as 10mm.
CLICK HERE!!!
Old 02-19-2010, 08:45 AM   #3
SRallDay
SRallDay is an unknown quantity at this point
i have the same wheel specs. i have a 10mm on front and it barely rubs the spring of my coils. im going to get 20mm on the front just to make sure. theres a slight chance 15mm might not clear it
SRallDay is offline   Reply With Quote
Old 02-19-2010, 10:37 AM   #4
seto519
thnx for the info. i actually got megan coils. i guess ima have to get 20mm spacers then. thnx for the help guys! got the info that i wanted
Old 02-19-2010, 11:02 AM   #5
bshotts
bshotts's Avatar
bshotts is making a name for him/her selfbshotts is making a name for him/her self
Send a message via AIM to bshotts
I wanted to chime in and recommend at minimum a 15mm spacer to clear coils. This would give you a 153mm backspace, which is the most you can usually run with alot of the larger diameter coilovers. Good luck!
Quote of the year?
Originally Posted by projectRDM View Post
Zoom in a little more, it's not blurry enough.
bshotts is offline   Reply With Quote
