Old 03-10-2010, 05:13 PM   #1
Viet-Tam
Viet-Tam's Avatar
Viet-Tam is making his/her stupidity well-knownViet-Tam is making his/her stupidity well-knownViet-Tam is making his/her stupidity well-knownViet-Tam is making his/her stupidity well-known
Steering wobble after Q45 brake upgrade!
I just did the q45 brake upgrade. Now my steering wheel wobbles, it did not have this problem before the upgrade. I have new rotors and pads what could be causing this?
Viet-Tam is offline   Reply With Quote
Old 03-10-2010, 05:17 PM   #2
NINJASPY
NINJASPY is on a distinguished road
what did you change, thats your problem.
NINJASPY is offline   Reply With Quote
Old 03-10-2010, 05:27 PM   #3
Viet-Tam
Viet-Tam's Avatar
I installed q45 brake calipers, pads, brake lines, and rotors.
Old 03-10-2010, 05:30 PM   #4
yarou
yarou's Avatar
yarou is close to perfectionyarou is close to perfectionyarou is close to perfectionyarou is close to perfectionyarou is close to perfectionyarou is close to perfectionyarou is close to perfectionyarou is close to perfectionyarou is close to perfectionyarou is close to perfectionyarou is close to perfection
We have no idea what you did wrong. Have you even considered to take it apart to check if everything is tight? (the suspension in general)
jumbosandbox.blogspot.com
yarou is offline   Reply With Quote
Old 03-10-2010, 05:31 PM   #5
SoguRacing
SoguRacing's Avatar
SoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfection
Send a message via AIM to SoguRacing
check to make sure that the rotor is sitting flush against the hub. chances are that it's not. sand down the hub before you reinstall.
Pre Tune Checkup! Compression,LeakDown,Vacuum Test $80. Cams Install: $180
SoguRacing is offline   Reply With Quote
Old 03-10-2010, 05:32 PM   #6
ADiamond240sx
ADiamond240sx's Avatar
ADiamond240sx is an unknown quantity at this point
Did you put all the lug nuts back on?
Rebuilding it one bolt at a time. Got any spare bolts?
ADiamond240sx is offline   Reply With Quote
Old 03-10-2010, 06:02 PM   #7
Tom25666
Tom25666's Avatar
Tom25666 has made poor choicesTom25666 has made poor choicesTom25666 has made poor choicesTom25666 has made poor choicesTom25666 has made poor choicesTom25666 has made poor choices
the steering wheel wobbles when you hit the brakes or all the time?
I have 1000 hp. This thread is dumb.
Tom25666 is offline   Reply With Quote
Old 03-10-2010, 06:18 PM   #8
DrifterE
DrifterE's Avatar
DrifterE is an unknown quantity at this point
Did you get your rotors drilled to 4 lug or you have a 5 lug hub?
Where is my sig pic?...
DrifterE is offline   Reply With Quote
Old 03-10-2010, 06:51 PM   #9
Shadowhunter
Shadowhunter's Avatar
Shadowhunter is an unknown quantity at this point
That's a good question for starters.
Shadowhunter is offline   Reply With Quote
Old 03-10-2010, 07:35 PM   #10
mmdb
mmdb's Avatar
mmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymore
Retighten parts. Did you bead in the rotors correctly? Possibly warpage doesn't sound feasible since they're brand new.
Could be your wheel needs balancing. Try swapping front wheels.
.25 till 3
mmdb is offline   Reply With Quote
Old 03-11-2010, 11:32 AM   #11
S13NismoStyle
S13NismoStyle will become famous soon enoughS13NismoStyle will become famous soon enoughS13NismoStyle will become famous soon enough
+1 on making sure the rotors are sitting flush against the hub. I had this EXACT same problem. I had a metal burr on the inside of the rotor that was keeping the rotor from sitting flush.
Also, if you drill the rotors yourself for 4lug, I would suggest chamfering the inside and outside of the new holes you made. I just put the rotor in a vice and went to town with a round bastard file. This will help keep the new holes from binding against the studs when you put it on.
S13NismoStyle is offline   Reply With Quote
Old 03-12-2010, 02:51 AM   #12
dato
dato's Avatar
dato is an unknown quantity at this point
It's a rotor problem... Ok. So u got new rotors or resurfaced?? If resurfaced they were not done right.. Warp rotor or they just didn't cut enough material of from the rotors
dato is offline   Reply With Quote
Old 03-12-2010, 08:10 PM   #13
FaLKoN240
Super Moderator
FaLKoN240's Avatar
Trader Rating: (73)
Feedback Score: 73 reviews
Tons of responses, nothing back from the OP.
Old 03-12-2010, 08:37 PM   #14
zenkifem
zenkifem is an unknown quantity at this point
how tight are you lug nuts / rotors to the hub?
also your rotors could be warped causing the wobble.
zenkifem is offline   Reply With Quote
Old 03-13-2010, 07:26 AM   #15
FaLKoN240
Super Moderator
FaLKoN240's Avatar
Trader Rating: (73)
I'm pretty sure new rotors aren't supposed to be warped.
Old 03-13-2010, 08:04 AM   #16
MavericStephenc
MavericStephenc's Avatar
MavericStephenc is close to perfectionMavericStephenc is close to perfectionMavericStephenc is close to perfectionMavericStephenc is close to perfectionMavericStephenc is close to perfectionMavericStephenc is close to perfectionMavericStephenc is close to perfectionMavericStephenc is close to perfectionMavericStephenc is close to perfectionMavericStephenc is close to perfectionMavericStephenc is close to perfection
Send a message via AIM to MavericStephenc
They aren't. however if stored incorrectly the can deform. The boxes are labeled "lay flat" for a reason.
just like stated in above posts check wheel balance, re tighten, and inspect.
for good measure look at the other suspension pieces. what are the condition of your tie rods?
That kind of attitude is SHIT. People with that kind of complacent outlook on law and government are the bane of this country's existence. -Thesquidd
Boycott Berkeley and code pink
MavericStephenc is offline   Reply With Quote
Old 03-13-2010, 12:17 PM   #17
zenkifem
Most people who do q45 swap put on used junkyard parts, it's just a speculation Since there's a few things that can cause wobbles/shaking
Old 03-13-2010, 02:33 PM   #18
rocksteady_racer
rocksteady_racer is making a name for him/her selfrocksteady_racer is making a name for him/her selfrocksteady_racer is making a name for him/her self
Send a message via AIM to rocksteady_racer Send a message via Yahoo to rocksteady_racer
Ok well I'll just throw this out there. My 300zx brake swap in my 91 was pulling hard right everytime I braked. The reason was bad tension rod bushings so nothing was being held in place so it was yanking the wheel hard to the right. So maybe your bushings on your suspension setup are bad? Then again 300z brakes grip pretty hard.
rocksteady_racer is offline   Reply With Quote
Old 03-13-2010, 03:03 PM   #19
FaLKoN240
Super Moderator
FaLKoN240's Avatar
Trader Rating: (73)
He said he bought new everything...
Old 03-13-2010, 03:09 PM   #20
zenkifem
Thanks for stating the obvious BRO, sort of realized that after posting the first time...
Im just saying so when people search it up and try to troubleshoot, they can count things off....
