Old 03-12-2010, 12:20 PM   #1
MadScientist
MadScientist's Avatar
MadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really nice
AN Fittings Everywhere
There is NO Thread dedicated to this yet... oddly! Help me Find the information and lets make this a (Sticky).
EVERYTHING for the S-chassis, KA, SR, RB... that can be replaced with an AN Fitting!
A easy method to convert AN size to fractional is to remember that each AN number represents 1/16".
For example: -8 AN = 8/16" = 1/2".
Originally Posted by Slo_240sx View Post
Great thread, anything can be adapted for AN use. Though I do not have pictures of most of my build I will add some info:
AN (Army-Navy) Fitting Thread Size Chart
AN Size------------Hose Size----------------Thread Size
-3------------------3/16-----------------3/8-24 SAE
-4------------------1/4------------------7/16-20 SAE
-6------------------3/8------------------9/16-18 SAE
-8------------------1/2------------------vvv3/4-16 SAE
-10-----------------5/8------------------7/8-14 SAE
-12-----------------3/4------------------1-1/16 SAE
-16-----------------1--------------------1-5/16 SAE
-20-----------------1-1/4----------------1-5/8 SAE
"NPT" (National Pipe Thread) Thread Size Chart
Pipe Thread--------Threads per Inch--------Inside Dia.
1/8------------------27------------------1/8
1/4------------------18------------------1/4
3/8------------------18------------------3/8
1/2------------------14------------------1/2
3/4------------------14------------------3/4
1------------------11-1/2----------------1
Another common mistake that people often tend to do is use teflon tape/piping tape/silicone/RTV. Please remember everyone, DO NOT USE IT ON AN FITTINGS! The seal is actually the tapered angle at the end or inside the fitting. Using any type of added sealant can make your AN fitting leaks by creating a gap in between the fittings.
Brakes:
1/8 NPT - 3AN
1/8 NPT - 4AN
The entire Brake System is 1/8 NPT - 3AN or -4AN. I have yet to find a 1/8 NPT Bump-O-Stop Adapter for the Master Cylinder!!
Originally Posted by hayabusa160 from NJTuners.com
STEERING
High Pressure:
6 ft. of -6AN Hose of Choice
45 degree -6AN Hose Fitting of Choice
90 degree -6AN Hose Fitting of Choice
-6AN to 16mm x 1.5, AN to Metric fitting adapter
-6AN to 14mm x 1.5, AN to Metric fitting adapter
Comments: You only need about 1.1ft of the power steering hose.
Feed line (Reservoir to Pump):
6ft of -12AN Hose of Choice
-12AN Econ-O-Fit
Comments: I used 2ft of the hose because I relocated the reservoir. To make it look purdy, get two Econ-o-fit hose clamps. One goes to the reservoir and the other on the pump.
Low Pressure:
10 ft. of -8AN Hose of Choice
-8AN Econ-O-Fit
For the s13 chassis, you'll need two extra fittings. The s14 has a power steering cooler on the low pressure side, whereas the s13 is just a line going back to the reservoir. The cooler is just an aluminum tube that runs across the front of the subframe and back. The s14 can use a hose clamp (econ-o-fit) or whatever, but the s13 needs the following.
-8AN to 16mm x 1.5, AN to Metric fitting adapter
45 degree -8AN to -8AN
Comments: About 2-3ft of the hose was used. For the s14, you'll need two Econ-o-fit hose clamps. For the s13, you'll need only one. The other end uses the extra two fittings.
PLEASE - Only comment if you have information!!!!
Looking for Information:
Brakes:
Engine:
Turbo:
Intake:
Transmission:
Diff Housing:
I will Update ALL Info to the First Post!!
-Drew
MadScientist is offline   Reply With Quote
Old 03-12-2010, 12:30 PM   #2
Bushido
Bushido's Avatar
FYI, that high pressure steering hose setup is for a s13 pump. s14 guys will have to get a different fitting.
Old 03-12-2010, 12:41 PM   #3
MadScientist
Which fitting are you referring too?
what size?
elaborate...
Old 03-12-2010, 12:49 PM   #4
mr_eh
mr_eh's Avatar
mr_eh is an unknown quantity at this point
wtf thread is this on njtuners.com ? i'm a mod over there and can't find the thread
mr_eh is offline   Reply With Quote
Old 03-12-2010, 12:52 PM   #5
MadScientist
pm sent..................
Old 03-12-2010, 01:25 PM   #6
Slo_240sx
Slo_240sx is an unknown quantity at this point
AN Size Hose Size Thread Size
Pipe Thread Threads per Inch Inside Dia.
Slo_240sx is offline   Reply With Quote
Old 03-12-2010, 02:17 PM   #7
R33E8
R33E8 is an unknown quantity at this point
Yay, I love AN fittings!
Did you know you can get AN fittings at pepboys!?! I was quite shocked.. They mainly carried -6AN and -8AN but you can order any..
R33E8 is offline   Reply With Quote
Old 03-12-2010, 02:56 PM   #8
lazysk8er2
lazysk8er2's Avatar
lazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud of
supscribed for further info
Well i have a 95 240 and i like my cars low... But my parents don't like my wheels tilted
________________________________
lazysk8er2 is offline   Reply With Quote
