Old 04-12-2010, 08:05 PM   #1
s13rockford
s13rockford's Avatar
s13rockford is a glorious beacon of lights13rockford is a glorious beacon of lights13rockford is a glorious beacon of lights13rockford is a glorious beacon of lights13rockford is a glorious beacon of lights13rockford is a glorious beacon of lights13rockford is a glorious beacon of lights13rockford is a glorious beacon of lights13rockford is a glorious beacon of lights13rockford is a glorious beacon of lights13rockford is a glorious beacon of light
Send a message via AIM to s13rockford
drive shaft issue
Before anyone throws the "SEARCH!"at me..... I have a 95 s14 which had a KA and was 5speed. I put a redtop SR in and now the drive shaft that was in the s14 with the KA is to long, but everything i read tells me that the driveshaft that was being used for the KA and 5speed trans should work. So im pretty confused.... Help
s13rockford is offline   Reply With Quote
Old 04-12-2010, 08:24 PM   #2
gprb25
gprb25's Avatar
gprb25 is a glorious beacon of lightgprb25 is a glorious beacon of lightgprb25 is a glorious beacon of lightgprb25 is a glorious beacon of lightgprb25 is a glorious beacon of lightgprb25 is a glorious beacon of lightgprb25 is a glorious beacon of lightgprb25 is a glorious beacon of lightgprb25 is a glorious beacon of lightgprb25 is a glorious beacon of lightgprb25 is a glorious beacon of light
Do you have ABS on your car?
If so, the driveshaft lengths are different.
Change out the front section, or use this time to get a 1 piece.
gprb25 is offline   Reply With Quote
Old 04-12-2010, 08:52 PM   #3
clark
clark's Avatar
clark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfection
there is not much else you can do. bite the bullet like i did and get your driveshaft professionally shortened and balanced.
OR get a new custome one made up specific to your application.
clark is offline   Reply With Quote
Old 04-12-2010, 09:16 PM   #4
s13rockford
I do not know if the car ever had abs, would the ABS driveshaft be longer or the non ABS? Because if one is shorter then i need to get a hold of that one i suppose.
Old 04-12-2010, 09:35 PM   #5
Killa_D
Killa_D's Avatar
Trader Rating: (39)
Killa_D can only hope to improve
Feedback Score: 39 reviews
sell me your driveshaft and buy a new one problem solved.
Killa_D is offline   Reply With Quote
Old 04-12-2010, 09:41 PM   #6
s13rockford
Killa D, whats it worth to you. dead serious.
Old 04-12-2010, 09:58 PM   #7
gprb25
gprb25's Avatar
From what i've read/seen it goes
ABS has shorter driveshaft and longer pumpkin
Non-ABS has longer driveshaft and shorter pumpkin
Just take it to a driveshaft shop like Clark said and have it professionally shortened and balanced
OR just get a 1 piece
Old 04-12-2010, 10:10 PM   #8
s13rockford
yeah, looks like im going Z1 driveshaft. hopefully im just in need of an ABS one piece, i just dont understand how the driveshaft fit before and not now.
Old 04-12-2010, 10:16 PM   #9
Killa_D
Killa_D's Avatar
Trader Rating: (39)
shit idono 50 bucks i shit need the front section lmk.
Old 04-12-2010, 10:18 PM   #10
BDMs14
BDMs14 is an unknown quantity at this point
Try to loosen the engine/tranny mounts and also loosen the rear subframe mounts so that you can have some "play" and be able to jam the drive shaft in there.
Also, did you remove the sr trannys plastic dust shield at the tail end? I had a similar issue with my cousins sr swap and removing the dust cover resolved the driveshaft fitment issue.
Good luck!
BDMs14 is offline   Reply With Quote
Old 04-12-2010, 10:31 PM   #11
chucky norris
chucky norris's Avatar
chucky norris is an unknown quantity at this point
Send a message via AIM to chucky norris
i had the same problem all i did was remove the dust shield at the end of the tranny.
i just used a hammer to take it off
chucky norris is offline   Reply With Quote
Old 04-12-2010, 10:54 PM   #12
s13rockford
BDM and Norris, awesome suggestions. was the driveshaft slightly off or was it hanging down a few inches at the joint when you had the end where they were suppose to be at the trans and diff?
Old 04-13-2010, 10:11 PM   #13
s13rockford
dust cover is off, loosend motor and trans, moved things around, still to long though, Im stumped
Old 04-16-2010, 10:06 PM   #14
s13rockford
Wasn't sure if my car was an ABS car, so I borrowed a non abs driveshaft from a friend to compare, turns out i had a non abs. So the car was using a non abs driveshaft, but looks as though I now need to use an ABS driveshaft with my SR...
Old 05-10-2010, 06:43 PM   #15
s13rockford
got a one piece ABS shaft... fits
Old 11-04-2012, 11:43 AM   #16
240pimp
240pimp is an unknown quantity at this point
I figured out that it was the dust cover being too long when i was installing my 1 piece driveshaft. It was too tight to get mounted by 3/16. took it out and shortened it with a hand grinder/ cutoff wheel. Reinstalled the shorter dust cover to protect the driveshaft from getting covered with grit and road dirt where it goes into the trans. Worked amazing.
Didn't see anything about this, so i figured i would post it for others.
93 Hatch w SR20
240pimp is offline   Reply With Quote
redtop s14 drive shaft ka
