Old 04-15-2010, 03:11 PM   #1
doyle4281
doyle4281's Avatar
doyle4281 is on a distinguished road
What rear ball joint do I use?
I removed my rear lower control arms and both of the ball joint boots are ripped. I have removed the ball joints and need replacements. What ball joint can be used for the rear of an S14?
I know this has been discussed before, however none of the threads have a definative answer, just possibilities. Any help would be appreciated, thank you
doyle4281 is offline   Reply With Quote
Old 04-15-2010, 04:31 PM   #2
98s14inaz
98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection
Clicky Here
-Retired
98s14inaz is offline   Reply With Quote
Old 04-15-2010, 05:15 PM   #3
doyle4281
doyle4281's Avatar
Originally Posted by 98s14inaz View Post
Do you feel better?
Any constructive answers? There is no factory part #, some say B13 sentra, some say B12 sentra, some say same as front??????
Old 04-15-2010, 07:08 PM   #4
98s14inaz
Originally Posted by doyle4281 View Post
Do you feel better?
Then don't use factory part numbers. Search for companies like Moog and others. S13 and s14 rear ball joints have slightly different taper so that sentra stuff might not be true in your case. This has been covered to death premie.
-Retired
Old 04-15-2010, 09:06 PM   #5
doyle4281
doyle4281's Avatar
Since this has been covered to death, could you enlighten us and share the Moog part # for an S14 rear ball joint?
Old 04-16-2010, 03:06 PM   #6
98s14inaz
Why don't you use the search button. Teach a man to fish and all that lol
-Retired
Old 03-12-2012, 06:55 AM   #7
tuktuk23
tuktuk23 is an unknown quantity at this point
this shit never gets old
tuktuk23 is offline   Reply With Quote
Old 03-12-2012, 02:33 PM   #8
Jus Skott
Jus Skott's Avatar
Jus Skott can only hope to improveJus Skott can only hope to improve
Send a message via AIM to Jus Skott
did you actually just quote and make a comment from something posted on 04-15-2010, 03:31 PM while trying to be funny.
Looking for yard parts, PM me.
Jus Skott is offline   Reply With Quote
Old 04-15-2010, 06:05 PM   #9
stinky_180
stinky_180's Avatar
Trader Rating: (26)
Feedback Score: 26 reviews
i used 89 nissan sentra front ball joints on the rear lower control arms on my s13. they work perfect!
WheelsDirty
Old 04-15-2010, 06:08 PM   #10
racepar1
racepar1's Avatar
Trader Rating: (106)
Feedback Score: 106 reviews
There are a TON of threads out there on this, you really should have searched harder...
As for the balljoints B13 sentra front balljoints work, they're just a little tight to press in. I used a sanding drum on a rotary tool to open up the control arm a little for mine.
Old 04-15-2010, 07:38 PM   #11
240_fun
240_fun's Avatar
240_fun is an unknown quantity at this point
Same but as for s14 I couldnt tell ya...
Bit snug but nothing an 8 pound sledge couldnt fix
240_fun is offline   Reply With Quote
Old 04-15-2010, 09:15 PM   #12
aznpoopy
aznpoopy's Avatar
http://www.zilvia.net/f/tech-talk/13...-answered.html
S13 = B13 SE-R front, we used MOOG Part # K9449
S14 = Same as S14 front, I used MOOG Part # K9820
aznpoopy is offline   Reply With Quote
Old 04-15-2010, 09:23 PM   #13
doyle4281
doyle4281's Avatar
Originally Posted by aznpoopy View Post
I read that thread as well, although someone replied just a few lines below, that it is a fact that they do not interchange front to back.
Old 04-15-2010, 09:29 PM   #14
aznpoopy
aznpoopy's Avatar
duh. because its the moog front balljoint. there is no oem or oem replacement rear s14 balljoint.
if you've read through all these materials then you know the deal
buy the front balljoint (or some other non-exact balljoint) and force them into the rear
buy the entire s14 rear lower control arm from the dealership
buy the hardrace or megan misnamed "rear roll center adjusters."
Old 04-15-2010, 11:05 PM   #15
modestmouse
modestmouse is an unknown quantity at this point
I know you're tryin to be helpful but the Megan roll center adjusters aren't misnamed. That's exactly what they should be called. They are ball joints that have the ability to adjust the suspension's roll center.
modestmouse is offline   Reply With Quote
Old 04-16-2010, 10:49 AM   #16
aznpoopy
aznpoopy's Avatar
http://zilvia.net/f/tech-talk/130216...adjusters.html
Old 04-16-2010, 01:02 PM   #17
doyle4281
doyle4281's Avatar
ball joints
Many responses, although I am still unsure if I should use B12, B13, or S14 fronts?
Old 04-16-2010, 01:05 PM   #18
stinky_180
stinky_180's Avatar
Trader Rating: (26)
maybe you didn't see the post above....
WheelsDirty
Old 04-15-2010, 11:20 PM   #19
singlecamslam
singlecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymore
They dont adjust the roll center at all. Buy moog ball joints and relax.
Nothing says racecar like a stock car with no interior.
singlecamslam is offline   Reply With Quote
Old 03-08-2012, 11:08 PM   #20
MrMcgarrett
MrMcgarrett's Avatar
Trader Rating: (313)
MrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfection
Feedback Score: 313 reviews
Send a message via AIM to MrMcgarrett
The rear ball joints aren't sold by themselves.
You have to buy the whole control arm.
MrMcgarrett is offline   Reply With Quote
Old 03-08-2012, 11:28 PM   #21
97_kouki
97_kouki is an unknown quantity at this point
just did my entire rear end, i used MOOG (part#K9820) ball joint and it fit perfectly...!
97_kouki is offline   Reply With Quote
Old 03-09-2012, 05:48 AM   #22
thegentlemen
thegentlemen is an unknown quantity at this point
Oh damn no way! Well that makes perfect sense then haha thanks man
thanks for the part number I'll be needing the in the future, but for now I just robbed a lower control arm with a good ball joint off of my parts car
thegentlemen is offline   Reply With Quote
Old 03-11-2012, 02:19 PM   #23
thegentlemen
And just to clarify, when replacing the front lower ball joint on my s13 do I need to use sentra b12 ball joints as well?
Old 03-12-2012, 05:18 AM   #24
NismoPlsr
NismoPlsr is an unknown quantity at this point
S14 Front/Rear (moog K9820)
Taper low diameter 15mm
Taper High diameter 18.6mm
Taper length 23mm
Diameter where it presses in 41mm
S13 Front (Moog K9509)
Taper low diameter 15.8mm
Taper High diameter 18mm
Taper length 19.5mm 20mm
S13 Rear (moog K9633 [b12 front])
Taper length 23mm or 23.5
Diameter where it presses in 38mm
S12 || KN13 || S13 || B16
NismoPlsr is offline   Reply With Quote
