05-10-2010, 10:55 PM | #1 |
To every one out there with an ignition or no start problem!!!!
ok obviously i was one of those people that had everything set up right in my car but my car wouldnt start for some reason. Well i kept thinking and looking under my hood with my wife and she helped me locate this little black box looking sensor strapped to the ignition harness i saw that a lot of other 240sx s13 s14 and sentras and many other nissans have this little box. Well i took it out and it looked burned so i went to the junk yard and replaced it and it turns out that that little black box is like a capacitor and is connected to the green\black cable going to the ignition coil. So if any one is having problems with their car not starting pls pay full attention to this little box is a bout a half an inch long and a half an ich wide and is attached to the ignition coil harness. I hope this helps alot of people out there. Oh and if you can, try to eplace your coil with this also if you need too!!! Good luck peoples!
j.t. 1992 s13 se hatch (THE LITTLE CAPACITOR SAYS 2.2UF,2.2 OHM 50V ON THE TOP) Last edited by S13 IN MY BLOOD; 05-10-2010 at 10:59 PM.. Reason: UPDATE |
05-19-2010, 04:17 PM | #2 |
Whould ur fuel pump primer up when the black box wasnt replaced? Also is this with an sr? The only box i could find was a green box on the driver side next to the fire wall.
