Old 07-10-2003, 01:29 PM   #1
Pudula
Pudula is on a distinguished road
Send a message via AIM to Pudula
s14 Would this offset/wheel size work.....?
I currently have Eibach sportlines (1.9/1.7) drop with tokico blues, no camber kit. I want to get the most agressive wheel/tire package possible without stretching the tires too much. This is what I have come up with after some calculation, but dont know if this will clear suspension -
Front - 18x9 225/40/18 +25 or +20 (i dunno)
Rear - 18x10 255/40/18 +25
Thanks for the help anyone who can!
Ryan
Pudula is offline   Reply With Quote
Old 07-10-2003, 04:45 PM   #2
hookedup240
hookedup240's Avatar
hookedup240 is an unknown quantity at this point
Send a message via AIM to hookedup240
s13 or s14?
hookedup240 is offline   Reply With Quote
Old 07-10-2003, 09:41 PM   #3
Pudula
S14 (like the icon says)
Ryan
Old 07-11-2003, 01:01 AM   #4
RBS14
RBS14's Avatar
RBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura about
+25 in front is perfect. +25 in the rear is gonna take some crazy camber and fender rolling to make fit on a 10" wheel. do between 35 and 40 instead.
RBS14 is offline   Reply With Quote
Old 07-11-2003, 06:47 AM   #5
orion::S14
orion::S14's Avatar
orion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud of
Run +45 in the rear...
I have 17X9, +25 all around...with a ~2" drop from Tein HEs - The front fit nicely (-2.5 degrees of camber), but the rears leave NO room for more tire (even with -2 camber) - But I have 1.25" of more clearance on the inside.
So add and inch to my rears, and it would ALL have to be under the fender - Hence a +45, maybe even +50. But don't worry - It will still be flush with the fender.
Later- Brian
orion::S14 is offline   Reply With Quote
Old 07-11-2003, 11:31 AM   #6
Pudula
orion::S14 - - On your car, can you tell if you increased total diameter of the wheel/tire setup, would it be okay? I really want to run the most agressive 18 inch setup that I can.
Old 07-12-2003, 10:55 AM   #7
Pudula
Bump.
Old 07-13-2003, 10:59 PM   #8
RBS14
RBS14's Avatar
You can find out the circumfrence of the tire really easily. Just go to tire rack and look at 18" tires and see what the respective circumfrences are. Stock is 24.2".
Old 07-14-2003, 02:11 AM   #9
Pudula
I know that...I'm talking about the width of the tire that comes close to the suspension...I'll increase the width 3 inches, but those 3 inches won't all be going on the outside.
