Electric oil pressure not reading pressure correctly help??
Ok, Im using a stewart electric oil pressure, the sensor is connected to my greddy oil relocation kit by the oil filter.
On cold start I dont get any oil pressure at all, during driving conditon it only goes to maybe 20psi no more but my oil temp gets up to about 180-190 when warms. It drives fine, boost fine and idles fine. Im also using moble1 5w30 syn. oil. Any inputs, or my gauge is reading unless my wiring is bad somewhere.
Also I did some search and noticed that people using the greddy oil relocation kit seems to have a oil pressure problem.
Any one has an input on this?
I'm using an greddy oil filter relocation setup but my oil pressure sender is by the oem location. My oil temp is in the oil filter plate. I have a slight dip in oil presssure, but not as much as you're thinking.
#5 |
Its where the oem oil pressure dummy switch is located: to the top right of the original oil filter location; just to the left of the alternator. I'm using a electronic greddy oil pressure sender in that spot.
#6 |
![]() Join Date: Jul 2009
![]() Feedback Score: 7 reviews
probably has to be closer to the block, or maybe your gauge is faulty which i highly doubt.
Who cares if you have 800hp...... |
#8 |
not giving a fuck
![]() Join Date: Apr 2007
Trader Rating: (104)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 104 reviews
relocate the pressure sensor to ur stock oe location...
![]() ![]() PSN & XBL GT : Wh0pp3r68 CLUB LEXUS : Wh0pp3r ![]() |
#10 |
Yea i was checking my connection to the sensor and everything seems good. All my gauge is grounded to same location, and they all work fine except my oil pressure.
How do you guys fit the oil pressure by the block if I already have my greddy sandwich plate there? Reroute a new line?
#11 |
