S13 power passenger window won't roll up
Hey guys,
My passenger window worked this afternoon long enough for me to roll it down, but now it won't go anywhere. I took the door panel off and tested the wiring as you can see in the video below. Can anyone confirm that it's the power window motor? EDIT: embed code isn't cooperating, here is a link: http://www.youtube.com/watch?v=jPxQUFoL-4U Thanks. |
Keeping in mind that neither side driver or passenger controls would raise/lower the window.
I'm getting 12v through the voltmeter everywhere. Pulled the motor and ran 12 volt directly to the motor and it spins fine. I took apart the passenger side switch and couldn't find any obvious problems, except it just didn't work. But I figured out why it wasn't working, I can't get a good ground. The switch has a 5 wire harness: the white wire in the middle is +12v, the green / blue wires signal the motor and polarity and the two striped wires are ground. If I ran a separate ground from the striped wires to the seat bracket, the switch works fine. I can't find any obvious problems with the harness up until the door. It got too late to go any further. While I look over schematics, has anyone else had this problem? |
#6 |
![]() Join Date: Aug 2010
This
If the motor spins its obviously fine. Can you hear the motor spin when you push the button? If not its a power issue/windows locked/ or switch problem. If you can hear the motor then its the regulator or window itself is off track. Friends been dealing with his s14 power windows for a year now. We've literally replaced everything and the motors still keeping frying out. |
power, s13, windows |
