Old 09-15-2010, 02:04 AM   #1
haro_ryder90
haro_ryder90's Avatar
haro_ryder90 is an unknown quantity at this point
Send a message via AIM to haro_ryder90
s13 need help setting the timing on my soch!!pleasee
whats up guys im rebuilding my single cam but i have a question about the timing...right now the block is ready for the rebuilt head to go on..i know the crankshaft and camshaft keyholes are supposed to be at 12o'clock with number 1 piston at TDC.before i bolt down the head is there anything special i need to do?i have read that wen u set the timing everything is supposed to be at TDC on the compression stroke then the oil pump and distributor are installed with the shaft looking like a backwards "D"...so my main question is how do i go about installing everything starting from where i stand?
this is my first engine rebuild so please bear with me guys
thanks!!
haro_ryder90 is offline   Reply With Quote
Old 09-15-2010, 04:18 PM   #2
kalypso123
(ノಠ益ಠ)ノ彡
Reading an sohc will give you the most information
Old 09-15-2010, 05:11 PM   #3
haro_ryder90
reading an sohc....i dont know wat that means??
please excuse my misspelled word...
Old 09-15-2010, 06:52 PM   #4
kalypso123
(ノಠ益ಠ)ノ彡
sohc Manual*
sorry that word was missing. I'd imagine thats the only way to get it perfect and understand what needs to be done flawlessly.
Old 09-15-2010, 08:37 PM   #5
jeremy242
jeremy242's Avatar
jeremy242 is an unknown quantity at this point
I just did mine today the chilton has all the info you need. I dont go anywhere with out it.
jeremy242 is offline   Reply With Quote
Old 09-16-2010, 03:04 AM   #6
haro_ryder90
i geuss ill have to get a manual then...thanks guys
Old 09-16-2010, 10:21 AM   #7
steve shadows
steve shadows's Avatar
yes....if you're lucky enough to have an engine in your nissan that actually came with the car indulge in the sweetness of an FSM or at least a SM of some kind....ftw
Like Me on FaceBook !
Old 09-16-2010, 01:41 PM   #8
jeremy242
jeremy242's Avatar
That is why i didnt go into detail about how to do it because without pictures or step by step details it would be pointless
rebuild, soch, timing
