Requests are off the hook!
Ok...During a thread, a few people picked up on something I did this weekend and I got so many requests that my PM got filled up so I am going to show and post it here..
Now...what we are dealing with is somthing that is marketed but it did not really get a huge response...and I said to myself..this is a great idea...but it could be done better...so without further ado...here it is... Engine shock absorber. Not a rubber bushing in a small shaft but a true gas shock hand picked for compliance, very strong and relatively short and stocky. A shock witb a 2600 LB capability but short. I found it. took a lot of time to find it.' I rigged up a mounting system (not beautiful but very functional) and I installed it. WHOA MULE...what an improvement! When I start the car, instead of the shifter shaking about 1/2 inch side to side (engine, tranny etc) I get this super smooth startup. The car now feels like an SC 400 in smoothness during startup and idle. Damn I say.. Next, I get on the road and the head to strut tower vibration is not vibrating but emmiting this Lamborghini type sound that is sex to the ears. So I start up in first, move to second and lay into it at around 30MPH and I see the front fenders rising and being pushed back in the seat like not before.. Instead of power twisting on the driveline, it is going to the rear suspention. The shifter is hardly flexing and if you hit a gear, totally absorbed big time...tires come on line. You know how the older 300Z's would squat down? Now my 240 Squats like this ...front raises up and total stability. In wet weather, I used to fishtail with the open diff. Now, strait line pull, stability. Both tires are spinning...level and deep pull. Am I over hyping this? NOT!!!! You must do this and see for yourself. Best mod for the money.. I am working on a pretty mount but at this time, it works so well..I may keep it ghetto for a while. Ok..picture time.. BTW, you can get this shock through me and zilvia will make a healthy percentage. I will make 3 dollars on it..and zilvia can make almost 20 or you can try to source it. It is the only one I have found that does the magic..so if you want to help zilvia..I want West to provide the zilvia stickers and lets make this one of our first products offered...and it works big time. You think $50 for the whole mounting kit and shock would be too much?? This is for the KA24SOHC engine only at this point. At this price, Ziliva is makeing some change that is worthy. It is an awesome value. I make about 3 or 4 bucks...and you pay shipping. Zilvia can make 4/5 times what I make. Lets help the site pay for the new server and all...and your car will love it. Mine does...very nice mod. You don't love it? I will buy it back. you pay to ship (6 bucks?) DOHC and SR to follow and I will make killer mounts once I have the cars to measure. You can go buy a gas shock...this one is really thought out for compliance. Worth something eh? I cannot imagine driving my car again without it. It works great. Last edited by Bill Roberts; 08-11-2003 at 10:35 PM.. |
The ones that are out there for 79 to 99 bucks are clean...but they are simply a rod with some rubber bumpers inside. This is a full scale gas shock rated to 2600LBS. Very absorbant..and the engine is not resting on a "stop" of rubber so it is allowed to use other suspention points as needed...like motor mounts, transmission mounts and the rear suspention mounts...this takes all the shock away...where the rubber one creates shock at the frame and does not distribute the torque down the line.
This works big time. I can guarantee if someone gets it...they will love it. Mounts are something that has to be worked out. I have a system that is ghetto (pic) but bolts up to a KA, SOHC....for other engines, DOHC and S14, and the SR, RB and CA, I will need pics to design something, otherwise, I would sell the shock for 40 and you are on your own..and I suppose anyone with half a brain could build a mount..I did with OTC parts for 8 bucks. My car loves it...so much more expensive feeling...and a blast to get on it. Not hype, just rear tire bite...like none before. Last edited by Bill Roberts; 08-11-2003 at 10:47 PM.. |
I'm going to shoot you a PM in a couple weeks probably to buy just the shock. I'll make my own mount. Did you use this same type of shock for your tranny to frame connection? I'm still curious exactly how that all went together.
…Appreciate all your efforts Bill ![]() |
#5 |
No...the tranny shock is the direct replacement part for a Nissan King cab 4X4 using the Z24 engine. it was noticeable...but not like this...at all.
A search for this tiny tranny shock is of no use. no one talks about them, Nissan does no longer have them and it is a fluke of nature that that thing even exists at all. What is staggering, it directly bolts up beside the torque mount that comes standard with our 240's. It is only 6 inches long and had a 3/4 inch throw...but very stiff. This completly overshoaws the tranny mount to the point that if I were to take the tranny shock off, I may not feel its absence. This engine shock is RADICAL in its effects IMO. The higher up it can be mounted to the engine, the better. If you have your hood up and crank your engine, I get less than 1/8th inch deflection, used to get more than an inch. And this is with the tranny shock. The shock is so powerful that you have to compress it to mount it. It has tension. A monster shock (for an F350 ford) is about the same, only it is too long to be practical..this was research for about 1 year. That is worth something I hope. Their is a thermodynamic character at play here too. The mount I started with overheated the shock and caused it to be uneffective. The Ghetto mount is actually a heat sinc. Painted black it is a keeper. I used a series of spring compressors (7/32 thick) for my head to shock mount. The shock must be level. It matters dynamically and statically (physics rule) I want to offer at a profit for ziliva to pay for the server..it is about value actually. It works...and it works great. If I get 50 orders, the shocks go for 34 bucks, not 40...but if anyone sends me a request to buy (this is the first actual offer) I will get them in. Thanks for the kind words. Last edited by Bill Roberts; 08-12-2003 at 12:23 AM.. |
#6 |
![]() Join Date: Jul 2001
man Bill this item sounds unbelievable. I am really interested in this and am more then willing to help zilvia out in the process also. I have one question will this shock interfer with ka turbo cars?
life is what you make of it!!!! "well, I go out, I do the practice, I think about it and I concentrate on one small thing I can change that will have an effect. I make that change then I go out and drive to my maximum." -Ayrton Senna |
#7 |
![]() Join Date: Aug 2002
I looked at my engine bay and the power steering fluid reservoir blocks the way if I were to mount the shock like you did. I'm not sure about the layout of KA24Es but did you have to relocate anything? The only way I see to mount it on the drivers side is by attaching it diagonally.
#8 |
I dont see why not. It is far foward...but I do see a problem with the driver side PS fluid container.
Dynamically, the shock must be level. The side of the shock tower is thick...very robust. The mount I chose works ...but on an SR or a DOHC KA, the mount might not be there properly at the engine The key is to have the shock level. I toyied with doing it on the intake side and I just could not bring myself to mount it on the intake manifold or the plentium but since the force is absorbed, you could do a right side mounting and have the same benefit...because I went with a mount that was not good enough on the head for test..and no problem. I even reved to 8K and banged it good to the smell of rosting rubber, and the mount did not bend at all the bolt did not break and the shock did deflect about 1/8 inch. Normally I would have seen a full inch plus...and the shifter used to move almost an inch...did not jolt..just flexed about 3/32" so this thing kicks a$$ so far. The sound transmitted from the head to the shock tower has to be heard to be believed, very deep and growly...pretty sexy. It was a freebee feature that I did not count on sounding good..not vibration (that is absorbed) just a growl. 3800 in 3rd is an intimidating sound. A resonant feature that is harmony to the ears. Of course you are over the speed limit already in most places. The car is finally connected IMHO. It feels good. If I took it off, I would definitly know the car is "spounge mounted" |
#11 |
IF you can keep it level, and clear the hood, no problem. It is large, look at the pic of mine, big shock...the tower mount must be low enough.
Also, the engine moves side to side, you want as direct a link as possable. I do nmot think this shock is long enough to reach that far. I need to measure the reach. Cant you move the PS resv?? All you want to do is hook the engine as high as can be to the shock tower (solid) then it will work. Look at hood clearance big time. No fun it hitting your hood where you cant close it. The mounts, give another inch and a shade more for the shock body. That shock is close to 3 inches round. You are limited on length. Late here 215AM, day job at 6Am, see ya in the morning.. Last edited by Bill Roberts; 08-12-2003 at 12:14 AM.. |
#13 |
![]() Join Date: Apr 2002
Bill,
Can we discuss the need for a shock at all? The way I see it, with a compressive strenght of 2600 lbs, you might as well just stick a solid rod in there. I mean, let's run some numbers. Let's say your motor cranks out 200 lb-ft of torque (for the sake of round numbers). Let's just say the distance from the center of the crank to that mounting point is 2 feet (again for ease of numbers). That means the most force you will EVER see at that point is 400 pounds. You have WAY more strength than needed. Now, obviously, if your engine is taller or you have more torque, things are different. If you factor in the weight of the motor as a swinging mass, that adds to the mass being accelerated, but I haven't had a physics class in a LONG time and it's too early to start talking about that. Perhaps you can fill me in. I'm not trying to rain on the parade...just discuss. I'm thinking that perhaps the BEST thing for transferring force would be a simple solid rod. This could be adjustable like a strut tower bar, and made to look quite sexy. You said you have access to a machine shop... ![]() Eric p.s. I can't imagine why a motor would NEED to move around. I'm thinking it's all just to keep the wussy passengers from complaining about vibrations.
2002 Mazda Protege5 1989 S13 w/SR20DET (sold) |
#14 |
I actually tried a solid link. I did not like it at all. It is nasty on a speedshift. transfeered all the jolt to the frame affecting the driveability and even the cornering.
You need some flexability to keep the shock of the engine from breaking things like U-joints, gears, axel spindles. What this does is keep the motion less than 1/4 inch each way. the engine has freedom to move on short ocillations...it is radical shock that makes this thing work best. I think the 2600 LB rating is to fully stroke this thing in one second. It is rather easy to move shorter strokes..but sudden movements are heavily damnped. Lets compare driving with no shocks just rubber mounts (wheel suspention) VS a solid suspention (horrible, the tires would be the suspension) VS rubber (motormounts) plus shocks. Transfer if energy is smooth, solid...but not jolty. I think I simply got lucky on the dynamics of this thing. It seems just right. Cheap to try, full reversable if you dont like it. Anyone want to PM me, I can source the shock for you...but I would like for the site to make some money on it. Think of it as a donation to zilvia. |
#15 | |
"buddy jesus"
![]() Join Date: Oct 2002
if you can make one for the dohc, ill buy one
![]() or if you can walk me through it, ill just buy the shock... but it sounds amazing....cant wait, you should see if it does anything on the dyno, hey ya never know...
![]() Quote:
#16 |
well i got a ca18 but i am down to just by the shock. email me w details. [email protected]
#18 |
I am drawing up various mounts as we speak. I spoke with West about zilvia getting profit from this and he is thumbs up.
Included, I will front West some money to get some zilvia stickers and put them on the unit...so consider that my donation toward the site and the other profits as well. Here is the rundown: Shock by itself with sticker $40 Plus 6 dollar shipping 48 states. Canada, Alaska, HI., and other places will be slightly extra. Shock total 46 Dollars. Shock with mounting hardware. You will need to drill the holes in it..as your set-up may vary some. The shock holes will be drilled. All you have to do is drill the holes to mount the unit to your car in the bracket. The first ones will require some ingenuity as we will be debugging it...so bare with me on the mounts...the SOHC mount is a no brainer. The DOHC may require moving the PS fluid container. As long as the shock does not touch the hood and mount as high as possable, no problem. The Strut tower mount will all be the same...and it will be ready for using with a strut bar on top..using one strut bolt or the side of the tower using two bolts (again you will need to drill this hole or holes. A disclaimer that this is an off road device and Zilvia or myself or the manufacturer (gaberal) bears no responsability for its misuse , damage to your car or otherwise. in otherwords, something freaky happens, you are on your own. Lockwashers will be included. yo must check them from time to time as you do your lug nuts. I torqued to 16 ft lbs. You will need to agree. Mounting it to the exhaust manifold is not permitted. The transfer of heat could cause an overpressure and blow the shock. So far, I have run the crap out of my car, no problems..Shock does not get too hot to touch at all. 50 With Brackets 56 Shipped 48 states. Zilvia will make some money on this and you will love the results. I tracked the car today and it felt really good...especially forced downshifts and slides. Just much more predictable. You are no longer fighting the viscous motor and tranny mounts. It is a good thing. The beauty of this shock is that it is bi-directional, works equally good for accelleration and downshifting (deaccelleration) Email me at [email protected] for the details. First shippment goes out on the 22nd of Aug. If someone can come up with a better mounting system after I post the first ones...have at it...we are in this thing together. More shocks sold, a better zilvia. Remember, if you are a cheapskate and simply want to source the shock and buy it yourself...it does not fit an american made car, they are not that easy to get, and it does cost more than 20 dollars in lots of 12 units here. You could just get a 9.99 shock but the spirit of helping zilivia and this is the only place that you will see this...others will copy it I am sure once word gets out...but remember, this is for the Site. I will make enough to cover mailing them off and my time to get them shipped in here, and packaging...It is only fair since I found the damn thing. Last edited by Bill Roberts; 08-12-2003 at 08:28 PM.. |
#19 |
![]() Join Date: Feb 2003
I really want one as well (S13 SR in '92 coupe). I don't have any welding ability/knowledge so I don't think I could make my own bracket... what kind of stuff is involved in making the bracket? (you can PM if you'd like). I'm definately down with helping out Zilvia.net and the innovator of this product
1992 SR coupe, ~11psi a.k.a. "Zip-Tie" ![]() www.carolinanissans.com |
#20 |
No welding required! Everything will be ready to just bolt it on with bolts..You will need to get a drill press or just drill out one end of the bracket to mount to your car. The ends of the bracket that the shock mounts to will be prepared and bolted on and ready.
With no brackets...just some spare parts laying around, I was able to mount mine...ghetto...but it works! Who knows, I might just keep it ghetto since it works so good. I took parts from a spring compressor kit (8 clasps and 16 bolts) and made it work. (cost 8 bucks plus tax) All I had to do was drill 2 holes on the side of the strut tower and bolt it up. I want the mounts to be very professional looking and ready to go. Once we find out exactly how to drill them for other cars other than a SOHC, then I will do all the dirty work and even have an instuction manual. Last edited by Bill Roberts; 08-12-2003 at 10:32 PM.. |
#21 |
for the welding stuff, i meant making my own brackets
#23 |
Good news! I just finished a lenghty conversation with the mount fabricator. I am sending him out a sample shock and he has acsess to all the different engines that are put in 240SX's !!!
What this means is the prices I quoted may be exactly the same...but if I am subcontracting the fabrication of the mount, we must iron out the price. Depending on exactly what is needed depends on if a CA engine needs a different style of "to the engine" system VS an RB. Yes, SR DOHC SOHC, we are on. I priced the mounts at ten bucks. One mount is the same for all cars, the other is special. he may charge 5 for the standard shock to frame mount but different engines may be different prices. Shock to engine mounts may incorporate indivigual pricing so lets hold our horses and see what it will actually be. I wanted to sub this out anyway because a specialist in the fabrication of the mount would make this so clean and easy. If we go with level 3 hardware, tungsten steel mounts with heat sincs..of course it would cost a lot more. Right now, lets get the system on some cars and let folks talk about how they love it and the mounts will come..and soon. Those that want just the shock, email me now at [email protected] and I will tell you where to send the 40 dollars. I just called in an order for 24 units so this will happen. I believe in this project because it WORKS! Those who want hardware, do the 50 and it will be delivered on time...even if I have to make it. Once we get production mounts going, I will be happy to trade out if needed. Remember, my Ghetto mount works fabulous because the shock is level and dynamically working properly. This means it is not in a bind..it is absorbing d shifts and U shifts equally. Last edited by Bill Roberts; 08-12-2003 at 10:31 PM.. |
#24 |
Zilvia Contributor
![]() Join Date: Oct 2001
![]() ![]() Feedback Score: 1 reviews
Sounds like it's coming along well. Good to hear. I wonder if there will be any fitment versions available for a topmounted KA+T setup....
Take a look at this pic (Unstable Hybrids pic) ![]() Any ideas?? -m |
#25 | |
Autox Technician
![]() Join Date: Dec 2001
#27 |
Hmmmmmm...This sounds like a nice little mod for the money. I'll be e-mailed you in the next week for an order Bill.
Btw...I have the SOHC. Last edited by Fastback180; 08-13-2003 at 11:28 AM.. |
#29 |
I don't have an accelerometer..but the rating is 2600 Lbs maximum.
Now...this is how it feels.. When you get it...it fully extends out. It does not take 2600 lbs to compress it at all. I believe the rating is it can handle loads to 2600 LBS..so this said, you cannot move it over a distance of say an inch...really fast. It takes about 4 seconds to compress it ...say about 80 LBS of pressure. Does this make sense? |
#30 |
It seems like people are making this too complicated. It's a shock just like attached to your suspension. Works exactly the same way, the faster you compress it, the more resistance it has. I don't think rebound is ever as hard as compression. If you put it on the passanger side, it'd have to be compressed a lot when attached to give it room to move...I don't think it would work as well.
"According to the experts at Gabriel Ride Control, shocks provide resistance by forcing hydraulic fluid (oil) through valves in the piston as it moves up and down. Because the oil cannot be compressed, only a certain amount of fluid can be forced through these valves, which creates resistance to the vehicle movement. Premium shocks and struts are superior to regular hydraulic shocks because air in the shock is replaced by pressurized nitrogen gas. This advancement in technology prevents bubbles from forming in the hydraulic fluid. These bubbles, called foaming, reduces the ability of shocks to provide resistance and prevent bounce. Gas shocks also quicken the response of a shock's movement thereby increasing comfort and control under all conditions." I'm up for the dohc complete kit when its ready. |
