Old 10-03-2010, 09:34 PM   #1
Gription
Gription's Avatar
Gription is an unknown quantity at this point
Send a message via AIM to Gription
Hardly anything works- electrical problems
I've got a 93' hatch and I can not figure out what is going on. Yesterday all of my switches and things worked fine- headlights, wipers, warning chime ect.. Then today I found out that almost none of my interior functions are working. Headlight motors, interior lights, warning chime, clock, wipers, hazards; none of these things are working at all. The only thing that works is my headlights turn on but they will not pop up, and my high beams only work when pulling the switch toward me and only the passengers side high beam works.
I checked all my fuses and the all look good, so I'm thinking it could be a power wire that connects to all of these functions or something. Serious gremlins going on here.
Does anyone have any ideas on this? Thanks.
Gription is offline   Reply With Quote
Old 10-04-2010, 02:26 PM   #2
obsolete
obsolete is an unknown quantity at this point
did you check the fuse links in the engine bay?
obsolete is offline   Reply With Quote
Old 10-04-2010, 09:08 PM   #3
Gription
Gription's Avatar
Yes, checked everything. are these things controlled by a relay that could be shot? I've got to fix it this week.
Old 10-04-2010, 09:34 PM   #4
lightsource
lightsource's Avatar
Trader Rating: (41)
lightsource is an unknown quantity at this point
Feedback Score: 41 reviews
Send a message via AIM to lightsource
Did you check your dome light/interior fuse by driverside kick panel?
lightsource is offline   Reply With Quote
Old 10-04-2010, 09:39 PM   #5
redhatchy92
redhatchy92's Avatar
redhatchy92 is an unknown quantity at this point
are you running bigger wheels than stock and if so did you relocate your side harness???? that sound like thats the problem just check to see if the tire rubbed against the harness and if so your fucked...lol
to be faster you have to slow down
WTB OEM SILVIA AERO SKIRTS!!!!!! PM ME
redhatchy92 is offline   Reply With Quote
Old 10-04-2010, 09:47 PM   #6
Gription
Gription's Avatar
Nah its got nothing to do with the wheels chewing up the harness, this car is 4x4 status to the max and hasn't been driven in 6 months.
Checking all the fuses again to see if I overlooked something, but I'm pretty sure thats not it.
Oh also the power windows do not work.
Old 10-04-2010, 10:43 PM   #7
lightsource
Trader Rating: (41)
All sound symptoms of a bad fuse/relay. more than likely on the interior. It may be one of the function boxes that's connected to the harness. Check the FSM for electronics
Old 10-04-2010, 10:55 PM   #8
dreamin240sx
dreamin240sx's Avatar
dreamin240sx is an unknown quantity at this point
Send a message via AIM to dreamin240sx
why would he be screwed if his tired rubbed apart the harness thats what they made soldier for...
RB POWA!!!!!!!!
dreamin240sx is offline   Reply With Quote
Old 10-04-2010, 11:08 PM   #9
HPKMotorsports3
HPKMotorsports3's Avatar
HPKMotorsports3 is an unknown quantity at this point
made soldier for??? did you mean solder... lol
HPKMotorsports3 is offline   Reply With Quote
Old 10-04-2010, 11:22 PM   #10
lightsource
Trader Rating: (41)
Yes and No, depends on his definition of screwed. If he wants to spend hrs replacing possibly burned/mangled wire harness all day sure.
Depends on the person.
Old 10-05-2010, 06:38 AM   #11
obsolete
This def sounds like the main fuse link in the engine bay cause it seems like everything straight off the battery is working. Does your brake lights come on when you step on the brakes? Does your radio and gauge clusters light up when you turn the key ON?
you will need to get a multimeter and trace it out
Old 10-05-2010, 09:05 AM   #12
Gription
Gription's Avatar
I didn't check the brake lights actually, but yeah the gauge cluster lights come on except there are no digits on the clock.
There is one wire that is white, probably a 10 gauge, coming from the fuse block that I think may have shorted to ground one day, but I checked it for continuity and it was reading a signal.
By main fuse link are you talking about those big ol' green and orange fuses??
Old 10-05-2010, 09:50 AM   #13
obsolete
I don't know the color, but yea, it's the bigger ones with the clear plastic showing the link. one should be 75amp. Does the car start? Best bet is FSM. Damn s13 looks very confusing compare to s14. Try troubleshooting one thing at a time like the headlamp motor.
Old 10-05-2010, 10:07 AM   #14
Gription
Gription's Avatar
It does start, fuel pump works fine as does everthing else related to the motor. I tested another set of combination switches thinking they could have blown or something, but I got the same thing.
Yeah I'll check the fsm schematics but the only problem is I don't know what I'm looking for haha
Old 10-05-2010, 12:22 PM   #15
lightsource
Trader Rating: (41)
Just read dude, if you have questions post on here.
Old 10-06-2010, 07:51 PM   #16
Gription
Gription's Avatar
Okay so I've narrowed the issue down to the drivers side kick panel fuse block, but I can't think of a good way to test or replace it. Anything?
