Old 10-11-2010, 10:03 AM   #1
HPKMotorsports3
HPKMotorsports3's Avatar
HPKMotorsports3 is an unknown quantity at this point
s13 Hvac heat switch jammed
Im having a problem with my HVAC/Climate Control switch... Fyi its an S13.. Its fine for cold but when i try to move the lever from cold to hot it wont budge i put as much pressure to move it before i broke the lever... so i took apart the center console as in i pulled out my radio and climate control box... and it appears to be the cable is not movin so like an ass i pulled the cable and i guess i stretched it out or something.. my question is why would it be like jammed where i cant put it on hot and where the hell does that cable go to i took off the glove box and still couldnt find it..So Please any info because its starting to get cold out here and my fat will only keep me warm for so long... Also i used the search button 3 different times stating HVAC Problems, Climate Control Problems, Heat Switch Problems and out of 200 post all were about no a/c which i dont have or how to convert to electronic which i dont need to do or no lights, i did google same shit and i did 2 other forums and couldnt find an answer so save your use the search button... and for the MODS i didnt post is the small question thread because all the other HVAC problems are no where close to this so this could be helpful to someone else who has this problem if i can get a legit answer here... Please dont lock...
Originally Posted by shiftdrift View Post
you running on hopes and dreams?
HPKMotorsports3 is offline   Reply With Quote
Old 10-31-2010, 03:51 PM   #2
HPKMotorsports3
i fixed the prob... there was a switchblade stuck in the vent preventing the door from closing... mods please close and delete this thread since no one gave any answers...
climate control, hvac, no heat
