trans slips please help
Hi I just got my s13 delivered yesterday and the guy said the trans is messed up. I took it for a drive and drove nice for a few minutes. Then the Automatic transmission will slip and will stay in im guessing 2nd because I can go about 20 mph with the needle down in the 2000s. could this be 1st or second gear. Nonetheless I am wondering what could be causing this problem. When it slips i have to turn the car off for a minute and then it will go back to normal. when I got home it reaked of trans fluid also. im guessing its not computer related because that shouldnt cause the smell. Any help would be much appreciated. Thanks in advance.
Thanks. how could I check to be sure that the convertor is bad. Anybody else have any ideas of what is wrong. Could I need a rebuild or could it be something with the computer part, because my moms caravan has similar problems and they told her that she needs some type of new module of some sort. Thanks alot.
I checked the fluid and it is a little darker than my other car but it doesnt look terribly brown. Also the fluid is full. That would probably mean the fluid isnt bad right. So would it deffinitly be a new converter that I need. I would hate to buy a new tranny to find out that I could have spent hundreds less to fix it. Thanks if anybody can help me.
#5 | |
"buddy jesus"
![]() Join Date: Oct 2002
make sure that it isnt just regular tranny fluid...you need to use automatic tranny fluid. correct me if im wrong but the viscosities are different and so are their boiling points...
this may cause your problem, empty out all the tranny fluid, and fill with ATF plus, there might be metal shavings in the tranny fluid, so it couldnt hurt to drain it... -glen
![]() Quote:
#6 |
Yes but the fluid looks fine. Red fluid is for auto trans's. But why would the car smell of trans fluid after a couple of minutes of driving. what could the problem be, its not something permanent like broken parts because it works fine for a while then slips but If I turn the car off and then back on, the trans works good. then the problems start back up after a while. It seems like something that after a while messes up then needs to be reset. Does anybody know what I mean. Somebody out there must know what the problem is. Thanks.
#7 | |
![]() Join Date: Aug 2003
I got the exact same prob, maybe worse! No smell though... here's my post from NICO Mechanic section:
*Sweet, I jsut saved some storage space on Zilvia server! Thanks for posting this title thread!
KYB AGX w/ dust boots $500obo... sadly serious ![]() |
#8 |
![]() Join Date: May 2005
hey guys i am a trans specialist to ford not nissan but maybe i can help a lil bit. if it was the converter u wudnt get no gears because i will not drive the pumps properly meaning no line pressure hence no gear appiclation same thing if the pump failed. now from wha i am gathering u are having a flare in second u need to find a book on the shift patterns and find out what is applied in second gear which clutch packs etc etc. i am willin to help once i have sum info on what is applied. but from what i am hearing u may need to go in the transmission. u may have a clutch pack or bad piston that is no more good. because from what i am hearin when the tranny is cool it is fine but once it warms up it slips signs of a bad piston in the clutch pack drum. also when u see the fluid is really really brown or black thas signs of burnt clutches and steels and changin fluid will only make it worse at that point maybe to the point that the car will not shift at all.
#9 |
jy116 your converter is definately gone that or the pump but from what u explained i experience this one day on a test drive on a f150 and began to make like a grinding noise before i knew it the car couldnt move. the converter was chewed to hell and back. once the converter is gone u get no fluid pressure which means u cant shift and u cannot apply any gear. also sumtimes when the converter is gone the vehicle will stall when u try to put it in gear.
#10 |
![]() Join Date: Sep 2002
To check a converter you can do a converter stall test. Also look for leaks around the bellhousing. If it's a sticking check valve or piston usually a good tranny flush will make it like new.
My 240 vBgarage |
#11 | ||
Sounds violent, but Im guessing my car wont do anything = bad TC. It's not leaking, so must be something w/ internal fluid transfer/pump?... Either way, Il probly going to look for a 5spd/SR person who doesnt want the AT, Ill pay a 12 pack... firm haha
#13 |
Make sure you run the car at idle for a little bit after doing this to give the tranny a chance to cool down a little.
My 240 vBgarage |
