Old 08-26-2003, 08:38 PM   #1
russian
russian's Avatar
russian is an unknown quantity at this point
Send a message via AIM to russian
Talking need some help with noise.
not making it hehe, but
my car whines sorta like its reverse when in Gear and when in neutral-when i rev up. i thought it was powersteering, it whines too but a deeper note. im guessing 2 things - tranny, or the belt on powersteering too tight?
theres is a thread, so why does it sound like im in reverse
But, it doesnt include the whining if you rev up in neutral that i have. and it doesnt occur till the car warms up.
help me out guys.
I must break you.
russian is offline   Reply With Quote
Old 08-26-2003, 08:40 PM   #2
russian
russian's Avatar
btw, forgot to clerify.
it whines when engages in gear/reving and neutral/reving. does not make that noise at idle.
I must break you.
Old 08-26-2003, 08:55 PM   #3
hookedup240
hookedup240's Avatar
hookedup240 is an unknown quantity at this point
Send a message via AIM to hookedup240
Not sure if this is it, but i was hearing a whinning noise, just like you are describing about 2 days before my alternator went. It was really weird and i couldn't figure out what it was for those 2 days. Then my car didn't start, and figured out it was the alternator.
hookedup240 is offline   Reply With Quote
Old 08-26-2003, 09:04 PM   #4
russian
russian's Avatar
hmm being going on for like 2 weeks now. usially when alternator fails it just fails. i always had problems with alternators in all my cars tho lol.
I must break you.
Old 08-27-2003, 03:38 AM   #5
s13silady
s13silady's Avatar
s13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfection
listen closely to your car when its in neutral without pressing the clutch... does it make a winding sound then??? and when you press on it does it go away???
does your tanny slip occasionally?? i have the same problem... or almost at least... and i found out that it was my pilot bearing and throwout bearing...
might not be your problem... but it might help you out in solving what the prob is..
-ryan
s13silady is offline   Reply With Quote
Old 08-27-2003, 07:59 AM   #6
crioten
"buddy jesus"
crioten's Avatar
crioten is making a name for him/her selfcrioten is making a name for him/her self
Send a message via AIM to crioten
its not a belt whine is it? go ahead and tighten belts anyway, couldnt hurt...
IMG exceeds forum limit of 150kb
Originally Posted by Var
I'd rather take the bus with a bus-full of AIDS infected naked rape convicts than drive a VW.
crioten is offline   Reply With Quote
Old 08-27-2003, 03:13 PM   #7
russian
russian's Avatar
its prob the belts.. it whines only when it revs. so i guess its the belts, gonna retighten them.
I must break you.
Old 08-27-2003, 03:35 PM   #8
240Stilo
Junkie
240Stilo's Avatar
240Stilo is an unknown quantity at this point
Send a message via AIM to 240Stilo
Yes! I had the alternator sound too! Sorry, had to say it. Anyways...if your engine is in the same condition mine was it might have oil all over the place and most likely in the alternator as well. What I do every now and then is buy some alternator cleaner at Pep Boys and spray the alternator. I always buy the can that says it's for the ALTERNATOR and electrical stuff, it works really well. Sure enough everytime I feel it needs it I am correct, because the oil comes running out. This stopped the whinning noise completely. I was also thinking it was the power steering until I gave up on tightening and untightening of the belt.
I also figured out we're supposed to use Automatic Transmission Fluid in our power steering and I have been putting in power steering fluid instead. Regular power steering fluid supposedly messes up the power steering pump over time and I didn't know that. So I poured out what was in the power steering reservoir and poured in the ATF. I don't know if that also helped stopped the whinning but that's my contribution to your problem. Report back when it's fixed.
-Juan
240Stilo is offline   Reply With Quote
