Old 01-09-2011, 05:05 PM   #1
SRpetey
SRpetey is just really niceSRpetey is just really niceSRpetey is just really niceSRpetey is just really niceSRpetey is just really niceSRpetey is just really niceSRpetey is just really niceSRpetey is just really nice
Injector sprays constantly
When i turn the ingnition to ON the #2 injector in my SR20det sprays the fuel constantly and floods the cylinder. if i unplug it doesnt happen. Does this mean my ECU is bad and is always sending a signal to injector #2
SRpetey is offline   Reply With Quote
Old 01-09-2011, 06:11 PM   #2
anton1o
anton1o's Avatar
anton1o is an unknown quantity at this point
Send a message via MSN to anton1o
I wouldnt jump to that conclusion but have you tried any form of trouble shooting?
Moving the injector to a different spot for instance?
anton1o is offline   Reply With Quote
Old 01-09-2011, 06:17 PM   #3
importdude
importdude's Avatar
importdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond repute
Send a message via AIM to importdude
injector is stuck open
replace
ecu only primes rail no fuel should come out of injectors until u crank/start
built ka-t
importdude is offline   Reply With Quote
Old 01-09-2011, 08:22 PM   #4
SRpetey
replace
okey i did some trouble shooting. I swaped injectors from another cylinder and same problem. So the injectors are fine. The wiring is okey too.
The yellow/black wire that signals the #2 injector is being grounded at all times by the ECU. Even when the ignition is on off. I even used the plug from injector two and plug it to #3(the car was off n the rail was off) and it does the same thing.
Does this mean that i have to replace my ECU or is there a Fix for this problem
Old 01-09-2011, 10:01 PM   #5
importdude
importdude's Avatar
test it
fsm
built ka-t
Old 01-09-2011, 10:03 PM   #6
240sxrb25
240sxrb25 is an unknown quantity at this point
you have some sort of fueling issue
240sxrb25 is offline   Reply With Quote
Old 01-10-2011, 12:45 PM   #7
SRpetey
No its the ECU
Old 01-10-2011, 01:22 PM   #8
jspaeth
jspaeth's Avatar
jspaeth is close to perfectionjspaeth is close to perfectionjspaeth is close to perfectionjspaeth is close to perfectionjspaeth is close to perfectionjspaeth is close to perfectionjspaeth is close to perfectionjspaeth is close to perfectionjspaeth is close to perfectionjspaeth is close to perfectionjspaeth is close to perfection
Check the ground signal wire from that injector clip for continuity with the chassis to see if the wire itself is grounding out on the chassis. If not, then something internal to the ECU is causing the problem most likely....
Daily driven
jspaeth is offline   Reply With Quote
Old 01-10-2011, 02:20 PM   #9
nismoman
nismoman is an unknown quantity at this point
What he said ^^^ don't throw away the ecu just yet!
nismoman is offline   Reply With Quote
Old 01-10-2011, 04:20 PM   #10
SRpetey
Yeah thats what I did. I unplugged the ecu hardness and the injector at the plug. Then I checked the injector plug and its not grounded. It's only grounded when I plug back the ecu.
