BC "Stage 2" 264 VS HKS Step 2 264 Cams
I am trying to increase response in my setup so I want to get some 264 duration cams. I don't want to loose any power either as I made 335whp at 16.5psi.
This is my current setup: - GT2871R .64 (bolt on T25/8 style housing) - Internal Wastegate, HKS actuator - Nismo 555cc Injectors - Stock intake/exhaust manifolds - Stock TB - Power FC D Jetro - Full 3 inch exhaust - Huge FMIC - BC Step 3 272 Cams - BC Titanium Springs and retainers - Cometic Head gasket, ARP studs I am currently deciding between BC Stage 2 264 cams and HKS Step 2 264 cams. Both have the same duration but the lift on the BC cams is 12.06mm while the HKS is 11.5mm. Other than that, the BC cams are $330CDN and HKS is $600CDN. Just wondering if it is worth it to pay extra (almost double) to purchase HKS. Will I get any performance gain or am I just paying for the brand? Thanks. |
![]() Join Date: Dec 2004
Trader Rating: (58)
Matt beat me too it.
RUN JWT S3's (500 usd) and dont' worry about springs or retainers. More notes: -Don't run that Cometic gasket, look into an ApexI or Cosworth -555 cc will not be sufficient for the upper power that turbo can support. You want 615cc at minumum -Make sure you have a Greddy turbine outlet on that as well Other than that, check out the 2871r users thread....it's super informative (granted long) but tons of information.
