Old 10-05-2003, 10:27 PM   #1
hondaguy
hondaguy is an unknown quantity at this point
Send a message via AIM to hondaguy
KA automatic to 5spd
ok i have the chance to buy a 240 coupe only problem is thats it a AUTOMATIC,but it has very high miles on it,so i was wondering if i bought a new 5 spd motor and tranny, could i just swap that in, pretty easy??
if i had a dollar for every dollar i put in my car.........i would have all my money back
hondaguy is offline   Reply With Quote
Old 10-05-2003, 11:11 PM   #2
DuffMan
DuffMan's Avatar
DuffMan is an unknown quantity at this point
Send a message via Yahoo to DuffMan
Look in the faq section
DuffMan is offline   Reply With Quote
Old 10-05-2003, 11:28 PM   #3
hondaguy
ok i looked at the faq and didnt see anything...
Old 10-05-2003, 11:38 PM   #4
revat619
Retired General
revat619's Avatar
revat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfection
look harder man, trust me its there.
www.Jspec.com
www.SpeedAlliance.com
www.PoweredByMax.net
Instagram: @rjsladerade
revat619 is offline   Reply With Quote
Old 10-05-2003, 11:43 PM   #5
DuffMan
DuffMan's Avatar
try ... PAGE 2
Old 10-05-2003, 11:44 PM   #6
holisticbeatz
holisticbeatz's Avatar
holisticbeatz is a well-known jackass
http://www.240sx.org/links/installs/s14_5speed_swap.htm
Trust and I don't mean GReddy.
holisticbeatz is offline   Reply With Quote
Old 10-05-2003, 11:53 PM   #7
hondaguy
man that sucks ok thank guys i guess i'll keep my fastback then,at least thats a 5spd
Old 10-06-2003, 07:59 AM   #8
zenkiDori
zenkiDori's Avatar
zenkiDori is an unknown quantity at this point
Send a message via AIM to zenkiDori
it's really not hard or expensive. check this out.
it's more time consuming than anything.
zenkiDori is offline   Reply With Quote
Old 10-06-2003, 08:23 AM   #9
mrmephistopheles
mrmephistopheles's Avatar
zenkidori. look up 2 posts...
Old 10-06-2003, 03:02 PM   #10
hondaguy
so i cant just buy a new motor and tranny and throw that in there??
Old 10-07-2003, 12:00 AM   #11
zenkiDori
zenkiDori's Avatar
you can, but you'll need all the parts that make a manual work, like clutch master and slave cylander, brake and clutch pedals(whole assemblies), lines, etc.
Old 10-07-2003, 10:40 AM   #12
the head
the head's Avatar
the head is making a name for him/her selfthe head is making a name for him/her self
you don't need the brake pedal from a manual just cut down your auto brake pedal if you need any parts for this swap i think a have everything except the hardlines sitting around in my garage you can do the mechanical part of this install with a 12 mm socket and two drill bits the whole thing is rather simple and straight forward
I never knew you could do that with an eggplant
the head is offline   Reply With Quote
Old 10-07-2003, 03:20 PM   #13
hondaguy
where ae you located at?how much will you sell it for??
Old 10-07-2003, 10:50 PM   #14
the head
the head's Avatar
i dunno how much it would cost i am in iowa so it may cost a bit you should be able to find most of it at a junkyard i have a zip file that has all the part numbers and step by step instructions for the swap but it is too big to post here (2.50MB) and MSN won't let me e-mail it i will have to find a way to get it out there so people can use it but for right now i dunno
Old 10-08-2003, 10:38 AM   #15
knghtryde
knghtryde has a little shameless behavior in the past
it's actually pretty simple. I just finished doing the 5spd swap in my fast back about 2 weeks ago. We started at 11am and where finished by 7pm. As long as you have everything it's really simple to do. But it is a 2 man prject.
David Munoz,
1989 S13 KA24ET
1990 Infiniti Q45
To push oneself to the limit is all that
one can do. To quit is to die.
knghtryde is offline   Reply With Quote
Old 10-08-2003, 02:31 PM   #16
hondaguy
a knightryder check your mail i sent u a pm
Old 10-09-2003, 02:11 AM   #17
meme
meme is making a name for him/her selfmeme is making a name for him/her self
does the jdm clutch pedal setup from an s13 work on a usdm s13 or s14 chassis?
meme is offline   Reply With Quote
Old 10-09-2003, 12:11 PM   #18
knghtryde
Hey Hondaguy,
I didn't get your email. Email me at [email protected]. I'm haveing trouble with my Zilvia.net email account for some reason.
David Munoz,
1989 S13 KA24ET
1990 Infiniti Q45
Old 10-09-2003, 12:26 PM   #19
the head
the head's Avatar
i know it is the same as S13 not sure on S14 though
Old 10-10-2003, 01:13 AM   #20
DRFT
DRFT is making a name for him/her selfDRFT is making a name for him/her selfDRFT is making a name for him/her self
This question is a little different, it was explained in the FAQ or anywhere else that i have read. What about the tranny fluid pan? because whne i got the car(auto) the tranny was slipping so i changed the ATF and it ran fine. Since i will be doing the swap, is there a different tranny pan? if not what fluid do i use? do i just drain the ATF and fill it up w/ manual tranny fluid (if it exist)? and what about the OD?
DRFT is offline   Reply With Quote
Old 10-10-2003, 10:04 AM   #21
knghtryde
DRFT,
The manual transmission does not have an oil pan, and it does not use ATF. It uses gear oil. Just go to your local parts store and tell them you need gear oil for the Manual Tranny on a Nissan 240sx and they will direct you in the right direction.
On the over drive question. There is no Overdrive on a 5spd just a fifth gear. I am really confused about your question. If you are doing a 5spd swap, you are taking off all the automatic equipment including wiring. There is some re-wiring that you need to do.
David Munoz,
1989 S13 KA24ET
1990 Infiniti Q45
Old 10-10-2003, 10:38 PM   #22
jy116
jy116's Avatar
jy116 is making a name for him/her selfjy116 is making a name for him/her self
s13
Hey Hondaguy, im in the same situation... one step further. I actually bought the car... so if u do get the auto, lemme come help and learn from ur swap!... or else i may just shell out the doe and let sumone else do it.
How much the parts goin for from your garage "the head"? Im not sure how much it should cost cuz ive heard $400 to $600s... also, Im wondering if its cheapest to just go to a junk yard and pull it from a car there. I think s13s are all over the place.
KYB AGX w/ dust boots $500obo... sadly serious
jy116 is offline   Reply With Quote
Old 10-11-2003, 12:34 AM   #23
PAnut240
PAnut240 is an unknown quantity at this point
Send a message via AIM to PAnut240 Send a message via Yahoo to PAnut240
I have a 5spd that I'm accually trying to get rid of. The flywheel will probably need resurfaced and a new clutch, but I would hope you would be doing that anyway. Send me an Email. I'm up in Marrysville,CA and I want rid of this thing. Oh, there is nothing mech. wrong with it I just don't need 2 spair tranny's.
'89 Fastback  SR20det; Greddy Profec B II boost controller. HKS 262 CAMS. Greddy Radiator,pulleys,oilfilter relocation kit,boost gauge, rockerarm stoppers,intake manifold. Nismo Fuel Press Reg. Ferra duel Valvesprings, ti retainers. East Bear headlight conversion. Type X tail lights. Tien Suspension, Tanabe race exhaust.  GT 16" rims, Walbro high Pressure fuel Pump,  7pt rollcage. HKS BOV. Mandril Exhaust Man. GTR FMIC. BeeR Valve cover. JE Pistons and Eagle Rods.
PAnut240 is offline   Reply With Quote
Old 10-11-2003, 02:49 AM   #24
jy116
jy116's Avatar
So 89-90 trannys are OK even though theyre SOHC? Ive herd that the blocks are the same... but also that theyre different sumhow...
Old 10-11-2003, 03:45 AM   #25
DRFT
Are you trying to sell a whole car or jsut tranny? if it is a whole car how much? if it is a tranny do you have other 5spd swap parts?
Old 10-11-2003, 07:53 AM   #26
PAnut240
SR
Its just the engine and tranny. I got almost everything needed for the 5spd swap, except the clutch pedal, Master and slave. I'm also not sure if I still have the cross member for it. Price, not much. Here The engine Details are fairly simple. Its a 90 KA24E with approx 130k on it. Which still runs like a raped ape. Motor brackets w/o mounts. wireing harness and ECU. I do have some spair car parts laying around but anyone who's interested email me or PM me so I am not taking up too much space on this thread.
Later\
Jim
