Old 09-16-2011, 06:03 PM   #1
ayororo
ayororo's Avatar
Trader Rating: (25)
ayororo is an unknown quantity at this point
Feedback Score: 25 reviews
S13 Driverside window buttons not working need window up asap
Hey my driver side window buttons wont control both windows, but the passenger window buttons still work for that window,
So now my driverside stuck open
I can still hear the buttons when i press it and the fuse isnt blown,
Any solutions?
ayororo is offline   Reply With Quote
Old 09-16-2011, 06:35 PM   #2
afiser
afiser is an unknown quantity at this point
probably the amp (box that is mounted inside the driver side door panel) although i dont think your passenger would work if that were the case (idk if this is 100% true).
if it is not the amp then it is the actual motor, in which case the only thing to do is take the door panel off and unscrew the window from the mechanism and hold it up with tape(lol idk get creative) or something for a temporary fix.
afiser is offline   Reply With Quote
Old 09-16-2011, 07:08 PM   #3
hOngsterr
Bandwagon.
hOngsterr's Avatar
Trader Rating: (73)
hOngsterr is an unknown quantity at this point
Feedback Score: 73 reviews
what he said
check your window amp, open it up if you see a burned spot, resolder it, then bam-o it will work again, if not then its your regulator.
- Hong
OCD isn't so bad just means you'll spend more money then most people, but you'll have a quality car not a POS put together with POS parts.
Old 09-16-2011, 07:23 PM   #4
dontxploitme
dontxploitme's Avatar
dontxploitme is an unknown quantity at this point
this has been answered like 20 times... and btw there's a thread for this kind of stuff it's called the small questions thread. 597 posts in i would assume you'd know this by now...
dontxploitme is offline   Reply With Quote
Old 09-18-2011, 01:19 AM   #5
ayororo
ayororo's Avatar
Trader Rating: (25)
Noone had the same symptoms as I do,
Turns out ot was the fuse, and i keep blowing it so i need to find out why its blowing ( the fuse to the amp box)
Old 09-18-2011, 10:22 AM   #6
dreamin240sx
dreamin240sx's Avatar
dreamin240sx is an unknown quantity at this point
Send a message via AIM to dreamin240sx
take the connector for the buttom and get a wire and jump it to a ground and it will go up for now
RB POWA!!!!!!!!
dreamin240sx is offline   Reply With Quote
Old 03-31-2012, 09:50 AM   #7
dlciii
dlciii is an unknown quantity at this point
driver window
I am probably too late for you but I took apart my amp and found one of the solder joints had broken over time. It is a pain in the butt to remove the printed circuit board from the assembly, but open it up and see.
dlciii is offline   Reply With Quote
