Old 09-24-2011, 12:52 PM   #1
sil80d
sil80d is an unknown quantity at this point
z32 brake set
cleaning out the garage today i was able to piece together another set. here is the deal. front brakes are one 26mm and one 30mm aluminum caliper, i was going to buy another 30mm and use the 26mm as a core but never got around to it. the rear are z32 na calipers and the ebrake is the style that does not use the hub as a spacer, so it will work with any hub set that you have. includes 2+2 ebrake cables that will work with either an s13 or s14. 310.00 shipped will not split unless i have a buyer for everything
sil80d is offline   Reply With Quote
