![]() Join Date: Jul 2006
![]() Feedback Score: 14 reviews
Fal wiring into jdm s14
Usdm has 4 pin plugs. My jdm zenki harness has only 2 pins for the fan. Need help trying to figure out what would be the best idea to run this..
I read a couple of post about running the fal fans constant on with the ignition, and I read some post on how to intall but they are all semi ghetto wirings and half ass cut around the edges stuff. I would like to get this done proper (and the best way possible). Pic1 brown/white and black (have fsm and can figure out what they are ![]() pic#2 shoes the wires from fal fan.. they are already labeled fan one and two positive and negative.. ![]() So what would be the best thing for these fans? constant on or wire it to ac control? or would one constant fan be ok for stock ka daily driving and the other for ac controlled? Any help is appreciated. |
Best bet is an external thermo and two relays. like this: Derale 16759 Derale Electric Fan Accessories
If not external thermo get the relays, wire up the turnon pin to an ignition only power source, power from the battery and then to the fans. Did a quick search, check Post #18:http://zilvia.net/f/tech-talk/180236...fan-setup.html
Man w/ CTSV & a Car Seat
^^^^Ding ding ding....
There is no proper way of wiring FAL fans to the stock wiring considering the wiring is only designed to power the AC fan. You'd need to rewire aftermarket fans in with relays on a switch or get an actual fan controller. |
