Old 10-20-2011, 05:05 AM   #1
ezza
ezza's Avatar
ezza is an unknown quantity at this point
'tapping' into charge pipes
I need to take a vac line from my intercooler hot pipe for my boost control solenoid.
what the best way to get a vac pipe friendly fitting installed? prefferably without welding.
would one of these be ok? would it make a good seal?
This is the smallest i can seem to find which is 6.4mm, but if im not mistaken the vac tubing for the solenoid is 3mm
any thought?
ezza is offline   Reply With Quote
Old 10-20-2011, 05:54 AM   #2
Propaganda
Propaganda's Avatar
Propaganda will become famous soon enoughPropaganda will become famous soon enoughPropaganda will become famous soon enoughPropaganda will become famous soon enough
I'd use something like THIS
Propaganda is offline   Reply With Quote
Old 10-20-2011, 08:23 AM   #3
airman
airman's Avatar
airman is an unknown quantity at this point
^Yes, that'd be the best bet. Most likely your hot pipe is at most 1/16" and that's just not enough room for threads. The BEST thing would be welding, however.
2014 Absurdity Build
RIP S13 KA-T HX35 419whp
airman is offline   Reply With Quote
Old 10-20-2011, 08:31 AM   #4
surfpac
surfpac's Avatar
surfpac is an unknown quantity at this point
Like "Propaganga" said the cheapest best option, and clean looking.
http://www.frsport.com/index.php?target=products&mode=details&product_id= 7854
+1 for Frsport too!
surfpac is offline   Reply With Quote
Old 10-20-2011, 03:32 PM   #5
ezza
ezza's Avatar
I was thinking of using plumbing tape and a nut the other side of the pipe^
but yeah i think il use the fitting linked untill i get round to haveing my pipes welded (there are other bits i need adding/cutting out too)
thanks guys
Old 10-20-2011, 04:01 PM   #6
slider2828
slider2828's Avatar
This is what I did. I just tapped the pipe. screw in the fitting and then JBWeld around it.... done deal....
Turn and Burn!
Old 10-21-2011, 01:28 AM   #7
xdumbxguyx
xdumbxguyx is a splendid one to beholdxdumbxguyx is a splendid one to beholdxdumbxguyx is a splendid one to beholdxdumbxguyx is a splendid one to beholdxdumbxguyx is a splendid one to beholdxdumbxguyx is a splendid one to beholdxdumbxguyx is a splendid one to beholdxdumbxguyx is a splendid one to beholdxdumbxguyx is a splendid one to beholdxdumbxguyx is a splendid one to beholdxdumbxguyx is a splendid one to behold
another solution if your using stock turbo is to tap the 3 bolt turbo outlet, therefore you can have enough threads.
infinitwheels.com
pitgarage.net
xdumbxguyx is offline   Reply With Quote
Old 10-21-2011, 10:37 PM   #8
idahotuner
idahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond repute
Send a message via AIM to idahotuner Send a message via MSN to idahotuner
Yes I have done this a few times. Use JB weld not much on the fitting threads. Drill a hole about the same size as the nipple screw end. And put JB weld on it and thread it into your hot pipe the closer to the turbo the better response u will have
idahotuner is offline   Reply With Quote
