Old 10-31-2011, 08:18 PM   #1
drivesideways
drivesideways's Avatar
drivesideways is an unknown quantity at this point
Exclamation Fs/ft red top sr20det engine only
Engine only. Engine was swapped out due to bad injectors flooding the engine. Mechanic at the time said engine was locked up and was cheaper to swap out then open up. I took the engine to sr20store in Gardena, which did a compression test and opened up for inspection. Engine was said to rotate freely and holds strong compression #. All internals intact, missing parts are seen in pictures. Local pick-up only. Need to bring engine hoist for pick-up. Located in Rosemead,CA.
$old..... Please close
drivesideways is offline   Reply With Quote
Old 10-31-2011, 10:45 PM   #2
Cease_Super_Hicas
Cease_Super_Hicas's Avatar
Cease_Super_Hicas is an unknown quantity at this point
Send a message via Yahoo to Cease_Super_Hicas
Is there any thing wrong with it? Any compression numbers? And what kind of trades u looking for?
Cease_Super_Hicas is offline   Reply With Quote
Old 10-31-2011, 11:00 PM   #3
drivesideways
I had the motor compression tested @ sr20store in Gardena, they said the motors good (upper 90%), no way to know for sure until its all wired up. Most of the missing parts are seen in the picture plus flywheel in the rear. Trades-racing seats, set of wheels. Getting rid of it cause of space.
Old 11-03-2011, 10:59 PM   #4
Most Wanted
Most Wanted is an unknown quantity at this point
interested for a better price, if everything is all good with it..how did you get a hold of engine?
Most Wanted is offline   Reply With Quote
Old 11-07-2011, 12:34 PM   #5
drivesideways
Purchased the engine from gspeed corp, Hawthorne CA.
Old 11-08-2011, 02:06 PM   #6
Most Wanted
whats your contact info to get a hold of you?
Old 11-10-2011, 05:16 PM   #7
drivesideways
TTT
Old 11-17-2011, 05:28 PM   #8
drivesideways
PRICE DROP!
Old 11-17-2011, 05:50 PM   #9
turtlesRgreen
turtlesRgreen is an unknown quantity at this point
Wow theres a lot of risk, does the crank spin freely, do u have wiring harness and does the stock turbo come with it
turtlesRgreen is offline   Reply With Quote
Old 11-17-2011, 07:35 PM   #10
Cease_Super_Hicas
I'll trade u an apex n1 exhaust plus 100 on top? And it's for an s13
Old 12-16-2011, 10:39 AM   #11
drivesideways
Tempting, but will pass.
Old 12-16-2011, 11:13 AM   #12
MaRshMaLLow
MaRshMaLLow's Avatar
MaRshMaLLow has a reputation beyond reputeMaRshMaLLow has a reputation beyond reputeMaRshMaLLow has a reputation beyond reputeMaRshMaLLow has a reputation beyond reputeMaRshMaLLow has a reputation beyond reputeMaRshMaLLow has a reputation beyond reputeMaRshMaLLow has a reputation beyond reputeMaRshMaLLow has a reputation beyond reputeMaRshMaLLow has a reputation beyond reputeMaRshMaLLow has a reputation beyond reputeMaRshMaLLow has a reputation beyond repute
Send a message via AIM to MaRshMaLLow Send a message via Yahoo to MaRshMaLLow
if the cylinders got flooded with gas, then those piston rings are washed out and will need replacement .... did the engine stall on you while running or did u just try starting it one day and it wouldnt crank?
Keeping It Real Since 1985
MaRshMaLLow is offline   Reply With Quote
Old 12-16-2011, 02:54 PM   #13
s13turbo
s13turbo is an unknown quantity at this point
I got good offer pm me please
s13turbo is offline   Reply With Quote
Old 12-16-2011, 03:04 PM   #14
s13turbo
I got a good offer pm me please. Please send me your number so I can text or call.
Old 04-20-2012, 08:15 AM   #15
drivesideways
Still available.
Old 08-09-2012, 03:05 PM   #16
drivesideways
Ttt................
sr20 block, sr20 det, sr20 engine
