Old 01-17-2012, 02:29 PM   #1
d0pe240
d0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of light
rb25 will not go into gear
i swaped in an rb25 series 1 into an s13. i replaced the clutch/pressure plate with an 300zx na and a new rb slave cylinder before swapping it. got the clutch set from a friend, matched up fine and read it would work. bled the system, fired it up and nothing. adjusted the pedal and actually helped for about 2 weeks, pedal was stiffer than before. it would go into all gears, but needed force. then one day, tired to put it into gear and would not go. replaced the clutch master with an autozone one to see if it was the problem, bled the system and nothing. the pedal still feels soft. just dont know what happened. i tired looking for threads and couldnt find anything similar to my problem. any help would be appreciated!
d0pe240 is offline   Reply With Quote
Old 01-17-2012, 07:31 PM   #2
r33nota240
r33nota240's Avatar
r33nota240 is an unknown quantity at this point
they are a real bitch to bleed i would say its still that it took me like 45 min to get the air out of the slave cyl in my r33.
r33nota240 is offline   Reply With Quote
Old 01-17-2012, 07:48 PM   #3
r33nota240
r33nota240's Avatar
it goes into gear with the engine off though right?
Old 01-17-2012, 09:30 PM   #4
redline racer510
redline racer510's Avatar
redline racer510 is on the path to ruinredline racer510 is on the path to ruin
Do you still have the factory clutch damper? If so that might be your problem, they are known to retain air and take a lot of work to get all the air out.
WARNING: User has a low tolerance for stupidity. Post at your own risk.
redline racer510 is offline   Reply With Quote
Old 01-18-2012, 02:40 PM   #5
d0pe240
Yes it does go into gear with engine off.
Damper box was removed a while ago.
Are 300zx n/a and rb25 pressure plates the same? I know the clutch disc are.
Old 01-18-2012, 02:42 PM   #6
r33nota240
r33nota240's Avatar
i think so thats what i have seen used in the passed
Old 01-31-2012, 06:15 PM   #7
d0pe240
figured it out, it was the throwout bearing. but 300 zx n/a clutch, pressure plate, and throwout bearing works.
Old 01-31-2012, 06:22 PM   #8
r33nota240
r33nota240's Avatar
well good to hear u figured it out.
Old 01-31-2012, 08:28 PM   #9
rcdad123
rcdad123's Avatar
rcdad123 is an unknown quantity at this point
what happened to the throw out bearing? did it passed thru the pressure plate fingers?
rcdad123 is offline   Reply With Quote
