#1 | |
It's Always Broken.
![]() Join Date: Feb 2010
![]() Feedback Score: 14 reviews
Fuse Box Relocation - Need Help Identifying a Few Plugs..
So I'm about 75% done with my fuse box relocation and I need some help identifying these plugs. My 240 has been away for a long time so I don't really remember where these went when my car was actually together.
Pretty much I need to know if the wires need to go into my engine bay or if they can stay tucked in the car. Also I am not sure if it makes a difference but an LS will be going into this car so the wiring harness and transmission harness will be slightly different. ---------- Okay here we go, I dont know what these are or where they go: ![]() This plug, and it's backside ![]() ![]() This plug ![]() This plug and the harness attached to it (The cut green wire went to an ambient air temp sensor or something, was next to the hood latch on the front support) ![]() ![]() Can I just delete this? It goes to nothing. ![]() ![]() This plug..pink and green wire..it seems to be something to do with wipers? ![]() These three... ![]() ![]()
#2 | |
It's Always Broken.
bump. still need help knowing what these plugs are
![]() Join Date: Jan 2004
Trader Rating: (82)
![]() Feedback Score: 82 reviews
First of all I don't know what car... But it seems to be an s13 and those look like the lower harness plugs...
NEED Bolt kits for your car? |
#4 | |
It's Always Broken.
Yeah it's an S13 sorry about that.
A few of them i thought looked like lower harness plugs as well. But I coulda sworn a few of those were originally in the engine bay
#7 | |
It's Always Broken.
Im assuming the wiper fluid pump is the pink and green wire one? If so I'll be removing that...
#9 | |||||||
You're in luck. I just finished my friend's FULL engine bay wiring tuck and I've had to scour the FSM to know each wire's purpose. Here I go!
Dual Pressure Switch for AC Drier PLUG (E21) ![]() Quote:
White goes to alternator power. Black/Yellow is Ignition power to Starter solenoid. PLUG (E204) Quote:
PLUG (E203) NOTE: The white wire of this leads to the 75amp Fuse ![]() Quote:
Green/Yellow = A/C Relay Red = ECCS Relay Black/Red (fat wire) = Ignition Switch (key) and T's off to Fuse box which powers -Black/White = Fuel Pump Relay -Brown = Pairc-Solenoid Valve Green/Blue = Ambient Switch ACROSS going the opposite way Black/White = ECCS Relay Orange/Blue = Condenser Fan Relay Blue/Green = A/C Relay (PLUG E9) ![]() Quote:
HOW TO: S13 Fog Light Wiring : 240sx General Discussion Quote:
Front Washer Moter (PLUG E6) ![]() Quote:
Brown Plug 8 Wires: Yellow/Blue = 5th Position Switch Pink = Pairc Solenoid Valve Yellow/Red = 4th Position Switch Brown = Pairc Solenoid Valve ACROSS going the opposite direction Green/Orange = A/T Control Unit, Neutral Position Switch Black/Yellow = SMJ, Fuel Pump Relay Black Pink = Fuel Pump Relay Red/Black = ECCS Relay (PLUG E10) Gray Plug: (A/T model) Inihibitor Switch (PLUG E14) -This is where you get your Reverse Light wiring I can't tell the colors of the third plug with 2 wires. ![]() I hope this helps you out. PM me if you find any other unknowns. |
