Old 03-14-2012, 09:14 PM   #1
BlueMissle sx
BlueMissle sx is an unknown quantity at this point
Oil in the bottom of my inner cooler?
Ok soo a quick noob question,
So i was switching out the couplers on my inner cooler and there was an abnormal amount of oil in the bottom of my inner cooler and a tad bit in the pipes causing it to leak through the couplers. Answers would be greatly appreciated, im pretty sure it was motor oil too because it was kinda dark like the oil from the oil change i did later that day.
BlueMissle sx is offline   Reply With Quote
Old 03-14-2012, 09:34 PM   #2
slider2828
slider2828's Avatar
Its blow by.... it happens if you rev he motor a lot to redline, or PCV is clogged and needs replacing, or pistons rings are getting old.
If its a redtop, make sure you retain the black box between the cover and the original tubes because it has a restrictor in the tube...
You can look it up.
Just make sure its not excessive.....
Turn and Burn!
Old 03-14-2012, 09:58 PM   #3
BlueMissle sx
Oh Alright Thanks ill check that stuff out, umm is this common for people that drift?
Old 03-15-2012, 01:31 AM   #4
Tantwoforty
Tantwoforty's Avatar
Tantwoforty is an unknown quantity at this point
Could be your turbo aswell.. mine shoots alittle into my pipeing
Tantwoforty is offline   Reply With Quote
Old 03-15-2012, 03:07 AM   #5
BlueMissle sx
Makes sense thanks guys!
