Old 03-17-2012, 01:34 PM   #1
silvia1991
silvia1991's Avatar
silvia1991 is an unknown quantity at this point
Oil Pan Coolant Leak?? Hellllp pleasee
Ive posted before about a coolant leak but here it goes again.
The U Shaped hose behind the thermostat was leaking, Replaced it!
Waterpump = Bad. Replaced it!
Did a coolant flush and now something else is leaking!
I drove it around for like 5 minutes before it started to oveheat again, drove it home, checked under the car and there seems to coolant coming out of something i have no idea what it is. I Only know its right next to the oil pan, underneath the alternator.
im lost!! what eles should i do?!?! im running low on money and i just want to fix it. Ka24e btw. Also, pevious owner gave me the car with no fan whatsoever but a CX racing aluminum radiator is installed so its supposed to stay cool still right???
i need it for a DD and im very frustrated. Someone Help!!!!
http://media.photobucket.com/image/r...a/IMG_4282.jpg
Not my Picture but In the PIc the part im talking about is right underneath the alternator.
silvia1991 is offline   Reply With Quote
Old 03-17-2012, 02:11 PM   #2
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Pull the intake manifold and replace ALL the coolant hoses under there. If one is bad and rotted, all of them are probably bad too.
You need a fan, atleast slap the stock fan on with the shroud.
CLICK HERE!!!
Old 03-17-2012, 02:19 PM   #3
S-Nation S13
S-Nation S13's Avatar
Trader Rating: (92)
S-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-known
Feedback Score: 92 reviews
change all the hoses bc its the amount of work that you want to by pass..do it all at once and youll be happy that you did.
S-Nation S13 is offline   Reply With Quote
Old 03-17-2012, 02:22 PM   #4
Infamax
Infamax's Avatar
Infamax will become famous soon enoughInfamax will become famous soon enoughInfamax will become famous soon enoughInfamax will become famous soon enough
Check all your coolant lines, like fliprayzin said, make sure they aren't leaking and are tightened down. Check to make sure the thermostat housing isn't leaking. You'll definitely need a radiator fan, or else you'll overheat. The fan shroud will help a lot too.
Infamax is offline   Reply With Quote
Old 03-17-2012, 02:47 PM   #5
Project S13
Project S13 is an unknown quantity at this point
Check your freeze plugs on the side of the block. There.should be 3 on the intake side of the block and 2 on the exhaust side. If you need a picture. Google ka24e freeze plug images. Common problem. If it is that. Replace with brass freeze plugs. Google how to replace freeze plugs on ka24e there's a bunch of how to's
Project S13 is offline   Reply With Quote
Old 03-17-2012, 09:34 PM   #6
marks14
marks14 is an unknown quantity at this point
Also, I know its not really in the area you are talking about but check if the weep hole on the water pump is leaking. I thought my seal for my thermostat was bad and I ended up re-doing it multiple times until I figured out it was the water pump.
marks14 is offline   Reply With Quote
Old 03-19-2012, 02:52 PM   #7
silvia1991
silvia1991's Avatar
Got it! Turns out it wasnt that part i was talking about, i replaced the thermostat and the gasket it for it. No more leaks, but the ushaped hose behind the thermostat is a little loose and drips a tiny bit of coolant so got to get in there again. Also, anyone recommend any good electric fans? i read about the altima e fans but i was kinda looking towards a Taurus fan but i heard there not compatible with an s13?
