Old 03-31-2012, 12:42 PM   #1
Po_31
Po_31's Avatar
Trader Rating: (28)
Feedback Score: 28 reviews
s14 S14 Auto to Manual Wiring
NOTe: Guys before you read Keep in mind that This Is My First A to M Conversion, and yes other motors have better specs but the ka is getting supercharged and am not looking for other engines as of yet. Thanks.
Hey guys I'm just going to go ahead and cut to the chase,
I have an autotragic '95 S14 and am in the process of converting it into a manual. Basically '95 kae to a '97 Kade, now the Problem is the wiring. Because the '97 De came with its own harness and in the process of installing it I came to notice that the autotragic under-dash harness has different connections.
So My Question: would it be easier to use the original 95 E harness and do the modifications to it, and if so can and should I do the same to the auto tranny harness?
P.S.- can anyone explain explain the Starting System section on this site(Below), I know they are from the trany but dont understand exactly wich to connection to join together.S14 5-speed Transmission Swap - Electrical Connections
ALSO ILL PROVIDE PIC ASAP.
Thanks all answers will be greatly appreciated.
Old 03-31-2012, 12:59 PM   #2
NissanEnthus
NissanEnthus's Avatar
NissanEnthus is an unknown quantity at this point
Not sure what this means: "Basically '95 kasohc to a '97 Kadohc" Both KA's were Dual Overhead Cam. Only SOHC were S13's. Also 95-96 CPU's (most) were OBD1 where as the 97-98 had OBDII computer and wiring will be different.
Are you only swapping your transmission or motor with transmission??
NissanEnthus is offline   Reply With Quote
Old 03-31-2012, 01:01 PM   #3
Po_31
Po_31's Avatar
Trader Rating: (28)
motor with transmission together
Old 03-31-2012, 01:13 PM   #4
240sxScores
240sxScores's Avatar
240sxScores is making a name for him/her self240sxScores is making a name for him/her self
Send a message via AIM to 240sxScores
You have a 95' S14 and you're swapping in a 97' S14 KA and 5spd tranny correct ?
If thats true i dont know why you said "95 kasohc" as SOHC on came in 89 and 90 S13's.
The only wiring you should have to do is overide the Auto tranny wiring connector under the engine bay fuse box.
Oh and search s14 auto to manual here.
240sxScores is offline   Reply With Quote
Old 03-31-2012, 08:34 PM   #5
trale
trale's Avatar
trale is an unknown quantity at this point
240sx FSM, Full Service Manuals, S13, S14, KA24E, KA24DE : 240sx General Discussion
trale is offline   Reply With Quote
Old 04-02-2012, 06:20 PM   #6
Po_31
Po_31's Avatar
Trader Rating: (28)
Or Would it Be better to Install the Body harnesses From a Manual from the same year?
