![]() Join Date: Oct 2006
i'm confused with rocker arms!!! with tomei solid lifters
According to this write-up, it says that the rocker arms need to be cut in order to shim correctly in conjunction with the tomei solid lifters and the valves? Can someone verify that this is correct. I bought the solid lifter and i lost the installation manual.
"You need to get your rocker arm cut like shown as recommended by Tomei. The following is actually copied from Tomei’s manual. I think this is necessary because the solid lifter is higher than your normal HLA so when the cam lobe pushes on the rocker arm, the tip might dig into the shim. Also more chance of this happening with high lift cams." How to Build a 9000-rpm Head for your SR20DET |
Yes, that's what needs to be done, just like it states in the build thread he created. He also shows a picture of the diagram if I remember right..
