Old 05-10-2012, 12:00 AM   #1
bikerskater
bikerskater is an unknown quantity at this point
brake brackets for bigger rotors what you think??
so i have made these brackets at work for stock/stock bolting aftermarket calipers.
with these brackets youll be able to run:
stock oem calipers-11'' rotor, maybe bigger
q45/z32 calipers- 350z rotors(12.5'') or 350z brembo rotors(12.76'')
im not entirely sure yet but i believe a 13'' rotor will work with the z32 caliper.
im still doing some math and figuring other stuff out on sizing and what not.
but my idea is based off the fast brakes rear big brake kit and the brackets are based off the will wood brackets for their calipers
heres some pics do note these are still in the making and this is the first set:
bikerskater is offline   Reply With Quote
Old 05-10-2012, 12:17 AM   #2
future
future's Avatar
Trader Rating: (42)
Feedback Score: 42 reviews
How much?
Becausemymessageisalwaystoofuckingshort
Old 05-10-2012, 07:32 AM   #3
bikerskater
Once I'm finished prolly like 30 bucks depending on how much my boss cares about me using the material
Old 05-10-2012, 07:55 AM   #4
JFoxx
JFoxx has made poor choicesJFoxx has made poor choicesJFoxx has made poor choicesJFoxx has made poor choicesJFoxx has made poor choicesJFoxx has made poor choicesJFoxx has made poor choices
the metal on that bracket looks really thin.... what are you using?
JFoxx is offline   Reply With Quote
Old 05-10-2012, 08:05 AM   #5
cdlong
cdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant future
Send a message via AIM to cdlong
Is that installed pic seriously how they're supposed to be setup? Talk about a death trap. If that's really 1/4" aluminum, I guess it really doesn't matter that the pad is halfway off the rotor, cause that thing is going the snap right off.
Actually, I'm guessing that's a mock up of the z32 caliper/z33 rotor setup. The z32 rotor is 1.1" bigger than s14, but Z33 is 1.5" bigger than z32. It's not going to work on both setups, not well anyway. Stop hacking together shit that is meant to keep you (and others) alive and do it right.
cdlong is offline   Reply With Quote
Old 05-10-2012, 08:08 AM   #6
JFoxx
^^^that was my concern
i think that picture is before the larger rotor....(or at least i hope so...)
Old 05-10-2012, 08:09 AM   #7
S-Nation S13
S-Nation S13's Avatar
Trader Rating: (92)
S-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-known
Feedback Score: 92 reviews
material ?? interested but the kicker is the material lemme know
S-Nation S13 is offline   Reply With Quote
Old 05-10-2012, 10:57 AM   #8
bikerskater
It's 1/4 in steel and that is the z32 rotor with the z32 caliper with the bracket. And like I said this is just a mock up and still working stuff out. And the will wood brackets are .316 thick
Old 05-12-2012, 12:41 PM   #9
future
future's Avatar
Trader Rating: (42)
Pm me when this grts done
Old 05-12-2012, 12:57 PM   #10
cured13
cured13 has a spectacular aura aboutcured13 has a spectacular aura aboutcured13 has a spectacular aura aboutcured13 has a spectacular aura aboutcured13 has a spectacular aura aboutcured13 has a spectacular aura aboutcured13 has a spectacular aura about
I think you should make brackets to mount rear Altima or bigger rotors with stock calipers,
if you want to make some money. Front calipers are pretty much covered here.
cured13 is offline   Reply With Quote
Old 05-12-2012, 01:35 PM   #11
Krewlkid
Krewlkid's Avatar
Trader Rating: (26)
Krewlkid is an unknown quantity at this point
Feedback Score: 26 reviews
Rear setup IMO
Krewlkid is offline   Reply With Quote
Old 05-13-2012, 01:24 PM   #12
bikerskater
I plan to do both I just had something to go off of for the front ill try take some dimensions down this week
